Parking Brake Engaged Warning
Please, can anyone help? My 2008 Expy EL Limited is displaying, "Park Brake Engaged" in the display center. I have verified that the brake is not engaged. I replaced the Parking Brake Warning switch, and have checked the brake fluid level and verified that there are no leaks. I also checked the brake booster and could not detect any vacuum leaks. Has anyone else ever dealt with this or heard of it? Please help! The only other thing I can think of is the hydraulic pressure switch in the master cylinder.
Check the wiring for the switch for a short to ground.
Does the light go out if you disconnect the switch? |
No the light stays on
So does the red brake light in the instrument cluster. I've had it checked and there were no trouble codes. The technician suggested doing a computer reset. |
When checking for a short to ground, do I just unplug the switch and touch the end of the plug to a bolt?
I am having the same issue. Intermittent warning flashing on and off and sometimes staying on. Checked brake fluid level and replaced the switch. When I replaced the switch, tat seemed to help for awhile, but now it is bad again. Seems strange for an electrical problem to be "kinda" fixed. Any idea where to find a wiring diagram so I can figure out which wire is the ground?
