Well I adjusted the linkage to take slack out of it and checked all relays and nothing. Then I pulled the wire harness that is right above the shift lever on the trans and it fired up. Imguessing I just had a dirty conmection. Will have to clean it out later on. Thank God it was a simple fix and nothing expensive.
what fixed the problem?
Sorry for late reply on what the problem was but it ended up being the starter. Guess it would be good to post the fix for others who search. Apparently there was a bad connection or something in it. Took it to Autozone and they tested 2 times and worked fine but 3rd time it wouldnt do anything. New starter and no issues.
