Timing without a light
Real nite mare, just installed my third distributor in as many days, all Cardone re manufactures .
First one: engine ran great, but would die in the heat of the day -code 14, would restart after a brief cool down, but ran poorly, was fine again in the cool morning, ran strong second one: failed to even start the engine, Where's their quality control :-huh third one: engine starts, runs medichor, but timing is certainly off a bit, no pinging, runs better at 45 mph than out of the whole. Question is, can I fine time her without a light...mine has water damage, not sure that I need/want to buy another one at $80.- plus for a decent light. :-down...if this is really a stupid question that does not deserve an answer, I will understand :-X04 thank's for your thoughts |
You can set the timing with a vacuum gauge, which is quite a bit cheaper then a timing light.
I was forced to do it on mine due to the harmonic balancer has slipped. It seems to run pretty good even though, and will suffice until I can get a balancer on there. There's a link to the procedure and other info on the web. But basically connect the gauge to a good vacuum source adjust the dizzy to max vacuum then back off a couple inches. Vacuum Engine Timing | MILEPOSTS Garage (Tech Tips) |
You really need a light to get it right,, Maybe you could rent one????
i never use a light for mine. trial and error. #1 at TDC (comp stroke), rotor pointing to #1, advance a lil, drive, advance a lil, drive, once it starts pingin i back it off ever-so-slightly. all motors are different, especially when youre talkin SD EFI. . .each one will tolerate a different amount of timing. since its not my daily, ive always set it to run on 89 or 93, which tolerates a lil more timing for a lil more power. with all that bein said, i dont care what degree it is, i just care where it is in relation to pingin.
Just get a timing light , this guessing stuff just isn't worth it , you really need to know where the timing is.....Lew
I say get a loner or buy a 20 buck cheapo... No need for a 80 buck light to time these old dogs.
Originally Posted by lew52
(Post 10678017)
Originally Posted by '89F2urd
(Post 10678584)
why? i have a timing light, but dont need to bust it out everytime i set timing. its common practice not to use one. . . . .i can understand not feeling comfortable without one, or not feeling comfortable giving the advise not to use one, but one is not necessary. even when i use one, i go through the same process pushing it to the limit anyway then backin it off a hair.
This read's real negative, but its not my demeanor. Not trying to flame you. Just against this practice and for a reason. |
(Post 10678017)
X2 I'm with Lew on this one. I use a timing light. Granted I purchased it 20+ years ago from Sears, but it suits the purpose for what it was designed for. |
Originally Posted by Bankrupter
(Post 10678858)
Ever seen a piston skirt shatter doing what your referring to ? I mean if your drive with the wrench ready to go, ehhh, ok... your still not doing your motor a favor letting it ping in the first place. I have lost a Chubby 350 to detonation. What your saying works, yes. But its really hack to do and Id never recommend it to anyone nor do it to my own motor. No need to push timing to the limit for the small gain you get out of it.
(Post 10679303)
we arent talkin a high compression monster or a forced induction app, where detonation is much more violent, and failure is much more likely.
I have only had it happen and seen it happen one time.Then never let a motor ping again. As I said, chubby... it was a 87 3/4 ton carb/goodwrench 350 POS. It was pinging for some time however. Not a 10 min ordeal as timing was being set. |
I look for the spark trace on the rotor. Move the point of fire accordingly to the center of rotor. Mine has the balancer twisted about 100 degrees, so timing is not an option.
(Post 10678584)
why? i have a timing light, but dont need to bust it out everytime i set timing. its common practice not to use one. . . . .i can understand not feeling comfortable without one, or not feeling comfortable giving the advise not to use one, but one is not necessary. even when i use one, i go through the same process pushin it to the limit anyway then backin it off a hair.
Originally Posted by xxshine
(Post 10679950)
To me timing without a light is like checking the tires without a gauge.
"Hey, they're round, Let's go!!!":-missingt |
