instrument cluster 1999 f250
does anyone have or know the wiring diagram for the gauges on a 1999 f250 v10. trying to tap into the water temp gauge and oil pressure gauge
May I ask why?
Originally Posted by jc8825
(Post 10616634)
May I ask why?
for gauges, |
If you are installing aftermarket water temp and oil pressure gauges, I think you have to manually wire them to an aftermarket sensor. I don't think you are going to get a reading from the cluster, as it is not connected directly to the sensors, but instead reads from the ECM.
your probably right, but i have no clue were the aftermarket sensors go and cant find anything online about it
It would vary by gauge. Most gauges will come with their sensor.
yea they come with a sensor, just no instructions on where it goes. they are Xtune digital gauges
and so far no one can tell me where they go
Call the gauge manufacturer...
so, as the original question says, does anyone have or know the wiring diagram for the gauges on a 1999 f250 v10?
