HELP PLEASE!! 97' turbo removal 7.3 diesel
I need some help/advice. I'm replacing fuel pump/dampner. Does the turbo have to be removed to replace this??? The banjoe lines on the pump are not fitting under the turbo. What do I do???
Is there a trick to this job, without removing the turbo?? Thank You. Tim |
It does not have to be removed for the fuel pump, I'll see if I can find a link for ya
https://www.ford-trucks.com/forums/1...l+pump+removal
https://www.ford-trucks.com/forums/1...l+pump+removal Need more links, just search for fuel pump removal, that is what I did and got many results, these are just 2. Also, welcome to fte! |
I replaced mine without removing the turbo, it was probably a little more difficult because I didn't, but it can be done. I had one of my 9 year olds thread the banjo bolt back on since my hand is too big to fit under there, that was the only 'special tool' I needed.
