ANYBODY HAVE EXPERIENCE WITH DEXTER NEVER LUBE AXLES
I have a Mobile Suites with Dexter Never Lube bearings. I need to repair the brakes in one hub. I'm on the road and have limited tools but I think it would cost less to buy a torque wrench and a socket/power bar then to take it to a dealer. Here's the question: Once I have the axle nut off do the dexter bearings just slide out like the outer bearing on a greased axle? Or, do I have to remove the spring clip I see in the hub? Also, does anyone know the size of the axle nut, my 36MM is just a tad too small. Thanks for any help you can give me.
Originally Posted by StanleyZ
(Post 10597466)
http://i.b5z.net/i/u/1080235/f/Instr...59-831-00A.pdf Good luck, Steve |
Thanks Steve. There seems to be a typo on that page, like they combined the removal with the reinstall. But I think it tells me enough to get me going. There are two snap rings visible, a small one on the spindle and a large one that appears to be in a groove on the hub. If I read the page you sent me to right it is the small one that needs to be removed and then replaced. Thanks again.
(Post 10597930)
Good luck, Steve |
Subscribing! I carry a bunch of tools with me when I am on the road but no snap ring pliers..guess I better add that to the list as well.
Keep us posted Stanley. |
Originally Posted by senix
(Post 10598966)
(Post 10598985)
It's not the pliers I'm short of, it's the 1.5 inch socket and the 150 lb torque wrench. I can buy the wrench but don't know where to get the 150 lbs of torque. Guess I'll get a 10 ft long pipe and jump up and down on it.
The question of how many tools to carry is ongoing. At one point, when we had a large diesel motor home, I even carried a 3/4" socket set for a time. Now I have cut back. I carry a small basic set and rely on buying what I need, if the problem goes beyond what I have with me.
Steve |
Mine uses a 1 7/16 socket. Just remove the outer small safety snap ring on the spindle and remove the nut and the drum and bearing will slide off. My torque to 145-150 ft lbs. I'm not sure how many miles you have on yours but when I checked my at 75K this spring the inner race would move around in the seal and could see where the grease had leaked out of them so I replaced all 4 bearings when I was checking the brakes.
Denny |
(Post 10598985)
Denny |
Originally Posted by rvpuller
(Post 10599301)
My wrench is only is only at the most 24" long and I have no problem with the 150 ft lbs.
Denny Ditto Steve |
I'm pushing 70 pretty hard, but if I can untorque it I'm sure I can retorque. I found a shop that seems competent. They will do it but not til Monday. I want to be on my way Sunday. Think I'll go price the tools this evening and I may give it a go. If I recall right there was a small plastic or rubber looking band on the spindle, my thought was that it was there so Dexter could tell if someone had removed the axle nut. Am I right or is there something else to it? Thanks again, once more FTE is saving my butt. It's a great site with a lot of knowledge in it's users.
If you get the nut off just put it back on the same way it came off and go home, it's not rocket science just a big nut. If you look at it close the nut puts pressure on the inner race of the bearing. Just a big nut that is really tight:-drink
Denny If you have to buy a new socket and you don't don't know the size buy a 1.5" 6 point and it will work if you have the 1 7/16 like mine. Don't ask |
OK, I won't. I'll just buy both and return the one I don't use. Thanks again for the help.
