Anyone know of a source for new/repro parking brake return spring?
I've checked BOTP and Dennis Carpenter with no luck. The one I'm referring to connects to the tail end of the front parking brake cable (near the equalizer) and anchors to the frame crossmember, for a 79 F100. (I also will need one for the 78 shortbed I picked up last week)
If anyone could point me in the right direction as to who carries them (new or repro) I would appreciate it. Thanks. |
did you try LMC or NPD?
ASSUMING its a '79 2WD reg cab F100 (People need to post MORE info when looking for parts!)
D2TZ-2A651-C Parking brake return spring Bowman Sales and Service, Bowman ND has 1 (701) 523-3257 This is the only one I found |
TXCTYDPS "did you try LMC or NPD?"
Yep, I have a file folder with about 9 catalogs of aftermarket Ford truck parts vendors. Neither of those two showed a listing. Thanks for the suggestions though. mikeoOoOoO "ASSUMING its a '79 2WD reg cab F100 (People need to post MORE info when looking for parts!)" That is correct. Didn't think the rest made a difference on this part. mikeoOoOoO "D2TZ-2A651-C Parking brake return spring Bowman Sales and Service, Bowman ND has 1 (701) 523-3257 This is the only one I found " Excellent! That's exactly what I'm looking for. Thanks for the help! |
Originally Posted by jade79
(Post 10587949)
