dealer wants $2200.00 to replace particulate filter
2008 f350 112,00 miles just had the truck in for a miss and the dealer says the particle filter is cracked and wants 2200.00 to replace it. Does this price sound about right for the job.:-huh
Originally Posted by Bigpipes 35
(Post 10551770)
At this point in time with no warranty you may well be best off installing a delete pipe and tuning the truck. Most common setups can be had for less than $1,500 and you'd have a truck that would get better fuel economy, more power, and one less expensive component to break. Check out these guys: Spartan Diesel Technologies On edit: Where in MN are you from? I work in Hudson, WI, which is only 20 miles from St. Paul. |
Dealer cost on that part is $962.00 its also a super simply 40 min repair job. SO why the almost $1300.00 in markup?? The total repair should be around $1650.00 out the door.
Originally Posted by Crazy001
(Post 10551878)
Seems a bit high, but I'm having a tough time finding a price for the part. If your truck was built after 12/08, the part has an MSRP of around $1,500. What are they quoting you for labor?
At this point in time with no warranty you may well be best off installing a delete pipe and tuning the truck. Most common setups can be had for less than $1,500 and you'd have a truck that would get better fuel economy, more power, and one less expensive component to break. Check out these guys: Spartan Diesel Technologies On edit: Where in MN are you from? I work in Hudson, WI, which is only 20 miles from St. Paul. Hey Crazy , we are located by forest lake. |
(Post 10552081)
(Post 10552105)
Wow...we're about 40 miles from each other. I bought my '11 F350 from Tousley Ford. Which dealer is quoting the obscene amount for the DPF replacement?
Like Crazy said, since you are out of warranty you are better off spending $1200 or so and getting a DPF delete pipe and a tune. It is the best thing you will ever do to your truck.
(Post 10552198)
Hey Crazy I have a buddy that works in the parts dept at tousley. My dad has the 2008 down in branson Mo and its a dealer down there.:-drink
The DPF can be cleaned. Baked out or high pressure cleaning. Might want to check into that. Do the labor yourself. If it cracked then a must replace.
I'm not real sure about pricing (I dont see the bottom lines, I just do the work) But parts, labor, and diagnostic time might be close to that figure. And no, I'm not someone that just replaces DPFs solely because of sooty pipes.
Delete it, tune it and be done with it!
You'll be more than glad you did. |
Originally Posted by longview1
(Post 10553132)
Originally Posted by pyro2nite
(Post 10553956)
I agree with this. Just reducing the fuel contamination is worth it. The increase in fuel mileage is a bonus. To change mine over, tuner, delete pipe, custom tune 1125.00
It took me all less than a few weeks to decide when I bought my 2008. |
Isn't emissions equipment warranted for 10-years regardless of mileage?
Out of warranty?
Is tuning even an issue then? :-huh DPF-delete and tune, /thread... And when you do come to the Dark Side, don't forget to get your cookie! |
