Keyless Remote for 93 Explorer
Does anyone out here know how to re-program a keyless remote for a 93 ford explorer? I'm not sure if mine will use one or not but, thought I'd try. I got one off a person and I'm not sure how to set it up. Any help would certainly be appreciated.
Thanks, Trent |
locate the programming connector in the left rear quarter panel (2 pin) with key on short the 2 pins together, doors locks should cycle, remove shorting connection, press any button on remote, locks cycle again, turn key off, locks cycle again
I can not find the programming connector in the left rear quarter panel. I have a Ford Explorer 1993 Limited
Please help. ONly 2 pin is the one for the rear window wipers stuff. |
I found it!! It was hidden behind all the other wires. It is a 2 pin connector without anything else connected to it. I will take a picture of it and post it on here. I will have to wait until tommorrow as it is dark right now.
the re-program was so easy. I am so happy. |
We wait fotos with connectors!!
Its around keyless entry module? |
keyless entry
Please tell me where is this two pin connector in the left rear quarter panel. When you open the panel what area should I look at? HELP!!!!
If anyone has a photo or a diagram of this, would they please post it on this page? Thanks!
I am so sorry. I totally forgot about adding these pictures. Here they are. The two pin connector is just two holes really that looks like you would plug something in it. All you need is a wire and stick the ends in the holes.
Hope these help. these are from a 1993 Ford Explorer Limited 4x4 http://www.members.cox.net/danreeves/keyless%20001.jpg http://www.members.cox.net/danreeves/keyless%20002.jpg http://www.members.cox.net/danreeves/keyless%20003.jpg |
Can't find the connector.
I've been looking but I cant find a 2 pin connector. It wont let me view the pictures that were posted. If someone could just tell me the wire colors so I can just trace them.
