chevygirl_78 |
06-28-2011 02:02 PM |
Hello from St. Marys Ga
Hey my name is heather and I live in St. Marys Georgia, about 15 minutes from the georgia florida line. I work at a local shop here in town, and am currently working on a 2006 E350 box truck with the 5.4 engine. I need some help figuring out what is going on with this truck. There is a vacuum leak in the ac system somewhere, but I can not figure out where. While at idle the ac blows out of the vents, but as soon as you start driving it blows out of the defrost. I have done a vacuum pressure check on the actuators in the dash, as well as the one by the passenger kick panel. I checked to make sure all the hoses were connected like they should be too. I dont hear an air leak anywhere, nor do i see any bubbles when soapy water is sprayed on the hoses. We are not equipped with a smoke machine, so that test is out of the question unless there us an alternative to that test. Can anyone help me? I also have a 2004 F450 tow truck that has an ac problem as well. The compressor does not kick on unless it is jumped, but the system has about 35 pounds or pressure in it. Could that be a high or low pressure switch?
