F350 front Running lights aren't working!
Got my 02 f350 stuck in the mud a while back and had to get a deuce and a half to pull me out :-X24 (F250 couldnt do it). Anyway since then my front parking/running lights don't work.
-I have checked the voltage at the bulb socket....nada -I have of course checked the fuse and its fine (checked ALL fuses) -ALL other running lights are working including top clearance lights, dually fender lights, etc. |
Probably not helpful, but have you ever seen Chevy one light trucks??? About 20% of them have one light out. Don't know why, but perhaps Chevy truck owners know the reason why...
Originally Posted by Pappy1911
(Post 10504208)
Has this problem been resolved? I have the same issue.
Actually.. No.
I haven't even given it a second look. After trying to trace the wires and find a source of the issue with no success, I haven't even bothered since. I haven't tried to fix it being that it's a fairly negligible issue. Of course my turn signal lights do work though. |
Yes mine do too, but driving a commercial truck without lights working is asking for trouble. If I come up with a resolution I will let you know. thanks
Great, thanks very much.
If you have top clearance lights then by law you are perfectly fine, which is why it's negligible for me since I can still pass inspection. Of course on the other hand if you don't have top clearance lights then it's a bit more of an issue. |
