cruise won't work 02 F350
I bought an 2002 F350 and the cruise doesn't work. Looking for a starting point.
T%hanks for the help! Matt |
Does the cruise control light illuminate when you push 'ON', then 'SET ACCEL'?
Jumper the SCDS and re-test.
Originally Posted by projectSHO89
(Post 10482871)
What is the SCDS? I looked for a fuse but I didnt see one for the cruise. Nothing works. No lights on the dash or other buttons that are part of the cruise. Thanks for the help! Matt |
Sorry to bump this, but my 02 250 started doing this randomly too. At highway speeds, I was not able to set the cruise control even after toggling the switch on and then setting, multiple times. The little green speed control light flicked on and off in less than half a second.
Anyone got a clue what's up? |
Look at the sensor coming out of the anti lock brake module in the engine compartment. If it had the recall done then a fuse was added there to prevent these things from catching on fire. Check the fuse. If its an intermittent problem look at the butt connectors where that fuse was added, it might have corrosion at the connectors. I looked at the "quality" job my dealership did, drove it home and then replaced it all with watertight butt connectors and a water tight fuse holder. Just a suggestion.
Originally Posted by F-250 Super Duty
(Post 10597913)
Pinky, Follow the instructions given in post #2. The switch can become intermittent or exhibit high resistance and the quickest way to verify or exclude it is to bypass it temporarily. A straightened paper clip or similar works fine, just ensure it cannot short to ground during resting. |
okay I checked my fuse and it is destoryed by brake fluid that leaked on it. What size fuse should this have? Would this fuse being out also affect my brakes?
Thanks for the help! matt
(Post 10599103)
The recall added a fused harness to the SCDS on the master cylinder, not the ABS module. The harness is a factory-assembled unit and should not have an "butt-connectors" in it. See instructions for 05S25 with supplements.
Go to a dealer's parts window and purchase a recall kit that includes both the harness and the switch and replace both of them. About $20 or so for the parts.
My truck was not included in the recall. What is the SCDS?
That's the switch on the master cylinder that leaks. Speed Control Disconnect Switch.
Are you sure you weren't included in Recall 05S28? My 01 F250 certainly was. You can check for open recalls on your vehicle at Recall Notices| Ford, Lincoln & Mercury Owners | FLMowner.com |
clean everything up and put in a new fuse and cruise works like a champ!!! Thanks ProjectSHO89!!!! I will be cruising to SD this Oct.& Dec.!!
Matt |
