Rear sway bar install on a F350 with 20” wheels! (Pictures)
12 Attachment(s)
Backstory: I wanted the rear sway on my F350 SB truck, but because I ordered it with 20” wheels it was not available. So… after 3 hours of dealing with the parts counter dude at Ford., I ordered all the parts I needed to install the sway bar kit. Why 3 hours? Because the parts guy thought brackets had to be welded to the truck….not true! All this takes to complete is several parts and 30 minutes to install! So now I have the ONLY F350 Superduty with a factory rear sway bar with 20” wheels!! I want no one to install this rear sway bar until one month after reading this thread. I want at least 30 days to hold this title! Just kidding….enjoy the pictures and get to ordering!
<O:p Parts numbers and Price:<O:p</O:p QTY Description Part number Total Price<O:p</O:p 1 Bar-Stabilizer BC3Z5A772B 118.82<O:p</O:p 4 Nut-Adjusting SCR W707492S439 17.00<O:p</O:p 2 Link 7C3Z5K484F 62.30<O:p</O:p 2 Retainer 7C3Z5486B 29.30<O:p</O:p 4 Bolts for retainers N605920 S439 14.00<O:p</O:p Total price before Sales tax: $241.42 NOTE: The "Bar-Stabilizer" comes with the rubber bushings already installed on it, so don't try to order them. Order exactly what is shown on list above. See pictures below for reference. Attachment 202835 All the parts prior to install. Attachment 202836 Close up of link setup Attachment 202837 Retainer with bolts Attachment 202838 Hole on frame where the Link attaches to. Attachment 202839 Link attached to frame Attachment 202840 Stabilizer attaching to lower Link Attachment 202841 Retainer attaching stabilizer to lower shock mount. (Mount already on truck) Attachment 202842 Stabilizer bar installed....back view. Attachment 202843 Stabilizer bar installed....front view. Attachment 202844 To install the nut on the upper Link (Driver's side of truck), you need to lower spare tire to gain access to it. Attachment 202845 Then reach over the top of the Urea tank and tighten nut. I used a 18mm ratchet wrench and a "Stubby" 18 mm wrench to get the nut tight. It takes some patience since you can't turn the wrench very much at a time...but its worth it! Attachment 202846 Install complete....my rear end it SOOOOO tight it hurts! |
Great job. I did the same thing to my 07 that had 20" wheels. Everything fit perfect.
Nice job Sarge! Looks like a great mod and I for one appreciate you posting the details. Anyone know why they don't allow it to be a factory option?
I can't remember exactly, but I thought I read somewhere else it has something to do with (an often false assumption on Ford's part) the camper package and the rare person who would load a slide-in camper into the bed of the truck or something along those lines. I probably don't have that quite right, but I know when I ordered mine I could not order the rear sway with the other options I had selected.
Does anyone know if the same parts and install process applies to a 250? I would like to put one on mine as well now that someone else was kind enough to share the parts list. Thanks for taking the time to do that, Sarge! -Rob |
I hate to do this to ya, but I have to burst your bubble.}>}>
I have had my sway bar on since December, forgot to order the camper package which comes with the sway bar. And yes I do have the factory 20" too. |
After install, can you guys tell a big difference? When do you think it helps the most?
Biggest changes I noticed was doing a quick lane change and cornering. The back end is more planted and less lean.
Originally Posted by sledhead_24_7
(Post 10396083)
Originally Posted by robroy90
(Post 10396056)
-Rob |
Do you have some type of undercoating?
Sweet, thanks for posting the parts and the pictures - looks like another mod I want to do.
Great information and pictures. Thanks for sharing!
Why do they not come with if you get the 20" wheels? Do they assume that if you get the 20" wheels you will not be towing near the load you would if you got the 18"? Thanks
Originally Posted by maistroyoda
(Post 10396995)
Originally Posted by hschiro
(Post 10398849)
