Originally Posted by galaxie641
(Post 10394866)
Tell me a "manual regen" isn't them turning it on and letting the truck idle. Would make sense why my LOM reads around 3-4 every time I get the truck back from the dealer, also explains all the oil it makes.
Hi guys this is what i noticed with the latest flash. Today i got the message "drive to clean exhaust" so i took the truck on the highway then the "cleaning exhaust" came on and stayed on for the whole cleaning, when it finished the message saying the exhaust cleaning is finished came on. So maybe when it goes into a full regen now it stays on, had a lot of passive regen that the cleaning exhaust message came on for about 4-5 seconds and you don't see anything once it complete.
Since I got flashed last week mine no longer shows when it is in regen. I am so used to it I can tell. I am not sure if it is a sound I pick up on or what as I even notice in cruise when it kicks in. a quick glance down confirms it by the low boost pressure. A system check also confirms.
Originally Posted by 03SD6L
(Post 10397989)
This is the problem with the lastest flashes. It would be better to show the message all the time. |
I think ford took the full time msg away to try and cut down on how often some people see their trucks regen. Maybe they can slip some through without people noticing and cut down on complaints.
Originally Posted by senix
(Post 10398635)
You were not passively regening. What happened is because the message normally just stays on a few seconds, there is no way to tell when finished unless you cycle thru the screens. So after so many of the regen imcompletes it gave you the "Drive to Clean" one.
Stanley, you maybe right on the bug in the programming. I would say that is more the case then now..wonder if they are using windows vista?
I just think in the post above it was probably more of because of incompletions. |
(Post 10398851)
:-roll |
I have Vista and dont see why everyone hates it, although it comes out with updates almost as often as the re-flashes for the 6.4. Maybe there is a connection lol
i get the "cleaning filter" message about every 200-400 km, i take the truck on the highway and drive it until the message does not come up, this is going through the message screen hitting the set up button then reset and when the cleaning filter message is not shown any longer (about 20-30 km) the cycle is complete. You get the Drive to clean exhaust message any where between 2000-4000 km that is a full regen. That is what a Ford tech told me when i got the flash before the latest flash he alos printed out how that flash worked, i'll see if i can find it and post it. Now what is see happening with my first Drive to clean exhaust since the new flash is that it stays on for the entire cleaning and you get the message at the end that the filter is clean.
Since my truck has been flashed, it seems to be cleaning itself more often as well. The message does not stay on during the duration though but I kinda wish it did. I always try to run the truck until its finished and it would sure make it easier to monitor.
No message when cleaning
Since the update it no longer says cleaning exhaust. There has always been a distinctive odor when it is cleaning. Now the only way I can tell that it is cleaning is by the odor. It never last long either. Is anyone else getting the odor, or do I have some kind of leak while it is cleaning?
I never smell anything unless I am outside right after stopping.
Originally Posted by kl817
(Post 10406367)
I think the algorithm that runs the regens is not just based off a simple pressure differential across the DPF. It likely takes in account how much air mass is supposedly moving though the engine as well.
I once made a run with the back loaded up the I-5 Grapevine with 25psi boost most of the way just to be welcomed with a regen right after I got over the top and shortly after I let off the throttle. Nice... instead of squirting in a little more fuel on the way up on a hot engine, it chose to do it on light throttle on the way downhill. Similar thing happened on another trip up I80 leaving Reno going toward Sacramento. |
