Tires & towing (need recommendations)
Well, I am at a bit of a crossroads with my 2000 F250 SuperCab V10 4x4. When I bought it, I was planning on putting some larger Mud tires and going down that route with gears and Heavy-duty bumper and winch and stuff. My wife has now agreed to get a boat (18-24 ft deck or center console ~4-5k lbs) next summer and we can use this truck to tow it.
The problem is I need tires now & I have to decide what tires (and size) to go with. Right now, I have 285/75/16 on it with 3.73 LS (stock was 235/85/16). I am still wanting somewhat of an all terrain / Mud terrain. I have considered going with a little skinner / taller tire such as Eurekaboy (Stan) with a 255/85R16. I have also looked at some 265/85/16 Did some comparisons… http://img855.imageshack.us/img855/7867/tiresizes.png Does anyone have any recommendations on size or tires? I still want something that I can play a little in the mud but I also want something I can use while towing and get a “decent” gas mileage (I live on Gulf coast not to much as far as mountains and such here) Cheers!!:-drink |
BF Goodrich A/T, with the E-rated load for towing.
I am running 35" Toyo MTs and tow a 32' 5th wheel.
I doubt you will see much real difference between those 3 tire sizes, given same tread patterns. |
With the V10, you will have no problems towing that small of a load with any of those tires.
So the decision is more on cosmetics and function.... You mentioned fuel economy. Narrower is better. Probably 1-2 mpg between 235 and 285. But, if you like to drive out on the sand, wider is better. Also, H/T treads give best mpg, but luggy treads work better in mud. M/T's will cost you 1-2 mpg compared to H/T. A/T's fall between the two, with weight and carcass compliance (rolling resistance) the factors that matter the most. |
Originally Posted by _red rocket_
(Post 10384069)
Dry traction is good, wet traction decent, snow and ice...adequate if you have 4 wheel drive. They are not an MT or an off road tire, but do look half way decent. |
Hey neighbor, gatorbait. I can't wait for the fall. I like the 285/75/16. 265 would prolly be good also. I got liberators a/t from walmart and I've put 90k miles on them. Their only a D rating but I haven't had any trouble w/ them. I went w/ these cause walmart is everywhere and I got the warranty with free rotate etc. Its a good tire for around here.
I have always been a fan of most BF Goodrich tires. Just started looking at the BF Goodrich Commercial T/A® Traction. Commercial T/A Traction | BFGoodrich Tires and the Rugged Terrain T/A® Rugged Terrain T/A | BFGoodrich Tires I have the Touring T/A's on my sedan and had Mud Terrains on my 94 Chevy Blazer 4x4 "RIP".
And exiled, I am planning on finding a tire I can buy at Sam's Club for the exact same reasons, They are generally a bit cheaper than at Walmart and other places but when no Sam's around Walmart will service it also. :-X22 |
Originally Posted by redford
(Post 10386270)
We currently own a 2010 Sequoia and I immediately replaced the OEM tires with the BF Goodrich All Terrain K/A load rated E tires and they do extremely well for most conditions. We live in rain country with some winter snow/ice but I have also used them for towing, dry river cobble stone crawling, beach sand as well as street and have been very pleased. I recently bought a beast which will be getting the same BF Goodrich All Terrains once the OEM Michelins wear out and that is now our primary TV. |
(Post 10386270)
Mostly I would need for Mud (often clay based dirt roads) and getting to the hunting locations nothing tooo bad. Half of the time I don't even have to engage 4x4. :-X22 BUT I would like something that has a bit of traction that could get me out... |
Go with General Grabber A/T2. A better reviewed tire than the BFG All Terrains. Slightly cheaper. I have the Generals and they are a great set of tires.
