70's 351 Serial #?
Where the hell do I find the serial number for my 351?
I've been looking for hours now, scraping off crud and dirt from under my truck and I can't seem to find it at all. I didn however, get the number off of the starter. That was an easy find, but nothing else! Any help on the location? I've heard behind the starter, but I just spent an hour with a mirror, flashlight and screwdriver, getting all the crud off the block in that location. To my surprise, ZILCH! Nada! No comprendo! Where the hell is this #?? Here is the serial # for my starter, don't know if it helps for decoding my serial # for my block haha. D8AF-AA-8C2B |
That number you supplied for the starter motor, D8AF-AA-8C2B, is not a serial number. It is a casting or engineering number. Being Ford, this isn't even the same as the part number, but a dealer can usually find the part number from the casting number.
Ford generally did not put serial numbers on these engines. |
While it is behind the starter you will have to look straight up toward the head. There is a flat spot with the casting number and will read like the number you posted.
