P0708 - 2001 Ford Ranger transmission range sensor questions?
I got a code P0708 and my check engine light is on and o/d light flashes on/off constantly.
Do you guys find that it is typically the sensor or the connector? Both? Also, any write-ups on how to replace the sensor? Thanks! |
Might be a bad connection, might be the sensor, might be the PCM, or might be the harness.
Start somewhere, like cleaning and reseating the connector, and go from there. |
Alright, today I replaced the transmission range sensor (neutral safety switch).
The first drive (for about a mile) ran great. The o/d light was not flashing anymore. Then, just going down the highway it all started up again. "First into second" gear shifts hard, but the other gears are normal. I also sprayed out the terminals at the range sensor plug. Any thoughts? |
Any ideas for those that have went through this?
