Exploded Diagrams
The all, I thought I was going to find what I was looking for in the "tech thread" sticky but the link wasn't working. I am looking for an exploded diagram of an '88 D60 and a tie-rod identification chart. If any of you would happen to have that, that would be great. I also tried to search it with no luck. Thanks in advance guys.
not sure of the model, but a king pin 60 is basically the same through and through.
https://www.ford-trucks.com/forums/7...d-a-trick.html and what do you need to know about the tierod ends? |
Those pictures didn't work, it said they have been removed by the creator. With the Tie-rods I am just trying to figure out which one is which. Like the inner and outers and left and right. I am also kind of curious to what other people have installed and like. This will be my first set of tierods for this truck, just over 200K miles and I want something that will last but wont kill my wallet. I dont do much off-roading, just looking for some quality tierods.
if i remember correctly, the tie rods are the same both sides and center link will only go on one way, with the drag link on the passenger side. same with the drag link that goes from the pitman arm to the center link it only goes on one way.
The creator giveth and the creator taketh away.
