How to tell is HPOP is going bad?
I have a 97 F350 with 185,000 miles on it, stock injectors, and all the mods in my sig. It seems like when I start my truck up cold and drive it, it seems like its lacking in power until it warms up. Is this normal? It also seeems to smoke more when its cold and i lean into the throttle than when it has warmed up. Was thinking i might have weak/leaking injectors or a bad HPOP. I also get a strong fuel smell from my tail pipe that seems stronger than it should be.
Thanks in advance. |
Nothing your describing seems abnormal. The fuel odor might be a concern if it was constant. If its there only when the engine is cold that seems pretty normal to me too.
Our engines are dogs when cold. Gotta give it some time to warm up.
Smoke is not abnormal as well as long as it goes away. To test the HPOP you would have to have a scanner to ICP and duty cycle. |
maybe egpv engaging when it's cold? wag!!
I didnt think about that, my egbv is wired open, could that be why it reaks like fuel?
Originally Posted by smash fascism
(Post 10326492)
(Post 10326492)
Are you due for an oil change? Get it on a scanner , let us see some live data... My WAG is the IPR is sticking ... |
yeah I know that, when the actuator broke it was a dog until i wired the butterfly open. im going to take that housing off this weekend and do the delete to it.
(Post 10326501)
Originally Posted by Action4478
(Post 10326527)
What part did you know ?
Originally Posted by JamesHajek
(Post 10324460)
ICP = Injection control pressure...
