Combustion Gas in Coolant
I've been monitoring my coolant pressure and from reading various posts on this forum, I decided to try the combustion gas test. Using leak tester from Napa with the blue fluid.
Well the fluid turned yellowish-green - a positive reading. I've read that this can be caused by leaking head gaskets or possibly some form of an EGR cooler failure-though not sure how. Are there any other ways that combustion gas could get into the coolant? Some other observations/points that may be relevant are:
Originally Posted by Scott6.0PSD
(Post 10274364)
is there any oil in the coolant bottle yes combustion gas can come from either a bad head,bad egr cooler, streched head bolts,bad head gasket cheezit had that vidio not to long ago |
refer to tsb 09 08 03 for this concern.
Originally Posted by cheezit
(Post 10278248)
Thanks, Scott |
Originally Posted by BLADE35
(Post 10274414)
have you parked the truck on a hill nose down and pulled the egr valve check the chamber it sits in it should be dry
is there any oil in the coolant bottle yes combustion gas can come from either a bad head,bad egr cooler, streched head bolts,bad head gasket cheezit had that vidio not to long ago I should have also noted that I do not have white smoke. Is there any other way that combustion gases could get in the coolant? For instance with the injectors, etc. Thanks, Scott |
I would suggest that you may want to hook up a pressure gauge in line with the degas bottle. also I would look at ect eot splits.
The chemical test is not the most accurate out there. you can also try to find a shop with a 5 gas that also works pretty well |
(Post 10279125)
The chemical test is not the most accurate out there. you can also try to find a shop with a 5 gas that also works pretty well EOT-ECT delta is 6 psi around town and 11 psi on the highway. Only time I've seen it go above 15 is after cresting a hill, where the ECT drops faster than the EOT. I've read where the gas test could have false negative, but didn't know they could also have false positive readings. What is a 5 gas? Thanks again |
ok so what is the pressure in the tank at WOT. imo this may be were you issue is comming from.
A 5 gas analizer is used in emmision testing for IM240 states (think califorina smog testing) one of the issues with the chemical test is deloution by sucking up any coolant, another is the age of the checmical. |
My truck was puking, but only sometimes at WOT or while towing. I'm sure that it started as stretched head bolts which lead to head gasket failure.
My shop was able to make the determination after about a day of diagnostics. If your shop is telling you they can't find anything wrong, I would suggest finding a new shop... |
(Post 10274414)
is there any oil in the coolant bottle yes combustion gas can come from either a bad head,bad egr cooler, streched head bolts,bad head gasket cheezit had that vidio not to long ago Ford Truck Enthusiasts Forums - Scott6.0PSD's Album: EGR - Picture And another of a finger swipe: Ford Truck Enthusiasts Forums - Scott6.0PSD's Album: EGR - Picture Felt more oily, but maybe this is the exhaust soot. I couldn't smell coolant, but I don't have the best sniffer either. Oh, and no oil noticed in the coolant. |
egr cooler is going IMO. thats what happend to me. i caught mine while it was in the wet stage and not the flooding stage like most. pulled mine off and coolant was coming out both ends. id say its time for a new one. BPD imo
What coolant are you using and is it at 50/50 concentration?
Early on, my EGR valve had oily sticky fouling. It was combustion related. A new valve, new flash updates, reduced idle time, and a good fuel additive solved that problem. Your EGR material looks like mine did. |
(Post 10279199)
A 5 gas analizer is used in emmision testing for IM240 states (think califorina smog testing) one of the issues with the chemical test is deloution by sucking up any coolant, another is the age of the checmical. For the gas tester, I don't believe I got any coolant sucked into it (coolant level was down at the sticker), though I could be wrong. Also the chemical was unsealed right before the test, or did you mean age in general, sealed or unsealed? |
Wow, you guys are fast!
rdunagan: Is being in the wet stage enough for the dealer to replace under warranty? bismic: I'm using the motorcraft gold coolant @ 50% concentration. Flushed this past summer & installed new upper & lower hoses. No reason except I was working through the maintenance since purchasing it used. I've now installed the coolant filter and am on the 3rd filter, though after opening the first two I didn't notice much in it, at least nothing compared to what others have posted. The dealer recently reflashed the modules for a smoking on start issue (didn't fix it). I'm using the motorcraft additive (antigel up to now) and I don't idle it much. I cleaned the EGR valve a month or so back and didn't look too bad this time. Is there a way to test if it is bad? |
I was hoping that if your coolant was VERY dilute, you would see some higher pressures. I hate to say it, but it sounds like head gaskets to me.
I do not know of a way to test the EGR valve. Is it the original? I forgot to mention that I changed mine out in 2008 because Ford had updated the design somewhat. You said they did TSB 09-08-03 ......... did they leak check the EGR cooler out of the vehicle? |
