Cruise and horn don't work
95 f-350 cc, neither the cruise or horn work, bought the truck that way a few months ago. I checked continuity from the horn switch to the relay connection, was good. If i jump the relay connector the horn sounds. Relay must not be getting power to 87 or 85 ? , I forget which was to the horn switch. Relay is good, swapped with fuel pump relay to check. Any ideas? Dont know where to start with the cruise...
Have a similar problem, Except all of mine works. When I was searching for answers, I came across a post from FTE from july 2010. Someone mentioned Bad clockspring, I think Lazy K was the contributor, in Steering wheel column. I wish I was on my other computer or I would give you the link. there are some diagnostics and if you don't find it, I will search later this evening for the link and Post back.
EDIT: Does the Airbag light flash? If so, this is it. If the airbag light doesn't come on with startup, bulb may be burned out too. A lot of people in the past, just ignored the light, and it would eventually burn out since it always flashed. |
Sounds a lot like a clock spring, especially if the horn sounds when the relay is manually activated. I replaced one recently in my son's 94 Bronco with a junkyard part. Just make sure to check continuity on the junkyard piece before installing it to save a second trip!
it doesnt have an airbag, and i do have continuity on the horn circuit from the horn button to the relay.
Originally Posted by timbersteel
(Post 10260019)
I located the thread here on FTE. I was mistaken with Lazy K as a contributor to the thread, but none the less, he is still a very knowledgable contributor to all of FTE.
If you scroll down to 87crewdually, he has the Document posted. If you don't have Microsoft Word, you will need to download a file viewer. Was easy and simple to do so! I hope this helps! https://www.ford-trucks.com/forums/9...l-problem.html If you have a problem with the document, I will adapt it to a text file for easier viewing. |
Thanks, there's a lot of good diagnostics there! I failed step one though, test the horn. Should there be power on 2 relay contacts for the horn relay? I have 12v on the feed that opens when the relay is energized, but shouldn't there be 12v on the signal for it when the relay is pulled?
