Nice writeup Ken.... My truck did the exact same thing. Glad you figured it out and was back on the road, I had my codereader but my kids took my fuse testers out of my truck so was forced to tow my truck home, not entirely their fault but didn't help matters, I might have figured it out:-arrgh. This site helped me figure out what was going on with much thanks..
Lost control of throttle & instrument panel dead
I experienced the same problem described above this morning. My 2002 F350 7.3D was ready to go to work this morning but died in my driveway. Chilton book was no help. Luckly I still had the owner manual to designate the fuses. I could not see any blown fuses obviously. Finally searched the net and found this site and this thread. I went back with an ohmmeter and systematically checked each fuse. #45 (ig sw feed) was blown but hard to see. Replaced the 10A and got're going again. Thanks a million, guys. High Fives for the internet and this blog.
Mick |
I am reading a lot of posts about this shorted O/D cable problem. I repaired mine with tape a few days ago, but last night it failed one more time again. My question is : if I disconnect the O/D switch for a while to isolate the problem some more, will that just allow the O/D to remain on or will it affect the PCM control of the transmission?
What if you are driving down the interstate with a 2000lb load and this happens ? You lose throttle control, what's going to happen next ? It seems to me this should be a Ford recall issue. Any comments ? |
Originally Posted by dobbinite
(Post 10672442)
What if you are driving down the interstate with a 2000lb load and this happens ? You lose throttle control, what's going to happen next ? It seems to me this should be a Ford recall issue. Any comments ? You might want to split open the sleeve and inspect the insulation on the individual wires. Chances are that you have bare wires in that sleeve and they are touching each other. I don't now what will happen if you leave that disconnected. If you decide to try running it that way let us know what happens. |
cable in shift lever
I unplugged the O/D switch from the steering column connector. The truck runs just as before, except of course you cannot turn off O/D.
I never used that switch much anyway, at least the fuse blowing problem has left. Since repairing the cable did not work, I will just leave it disconnected. A permanent fix will be replacing the shift lever and cable assembly someday. |
(Post 10706973)
shifter
I looked at PartsGuyEd site, but I can't find this parts under any of their categories. If you have their P/N I will order it.
Thanks, Mick |
(Post 10707108)
Thanks, Mick http://www.trademotion.com/schematics/M/ME99630.gif Edit: Tip - If you can get close click View Illustration and you may find the part. |
In Robin's picture above...
Hope this helps. :-drink |
Originally Posted by gchavez
(Post 10707313)
:-drink Right? Which items come with egg roll? :D |
Originally Posted by PaysonPSD
(Post 10707359)
Item #1 comes with #2 & #3, but #2 & #3 can be ordered separately.
Right?...
(Post 10707359)
Which items come with egg roll? :D I presume you'll be coming for Chicken Quesadillas on Labor Day weekend....no part number required. Just keep me away from your Kool-Aid. :-X21 |
oops! wrong fuse
OK, same problem with overdrive button. i put some tape around it and made it for awhile but had used all my 10 amp fuses. i put a 30 in it just to get back to camp where i had tools and fuses in my 97 f250 turbo diesel. didn't make it. i had a new shifter brought out to me and put it in with new wires but it didn't blow the fuse and now i have same problem with no blown fuse? just wanting to know if i should start at that wire or at the fuse panel??
reply
I just disconnected the overdrive switch. Its always in OD in high gear but thats OK works for me. If that does not work, you need to trace the 12v line to the IG sw and run a replacement wire.
Hope you didn't fry the wires in bundle. Auto Electric shops are good at fixing this kind of problem. |
(Post 12499358)
Thank you,i tried unplugging it, no change.i am blessed enough to have a couple other trucks so not in desperate need.just trying to figure it out.do you think start with the wire and work down or the back of the fuse box?
