A little video from the shop tsb 09-08-03
http://i547.photobucket.com/albums/h...0414011102.jpgsorry its not the clearist and its sideways but hey...
its a pressure tester hooked up to a degas bottle |
What PSI was it topping out at?
30psi if I could figure out how to post a video from photobucket and make it work..
for now you can click on it and be redirected |
I was able to watch it, just couldn't see the numbers on the gauge.
Sure jumped up there quick huh, blown head gaskets? |
so what does that mean streched head bolts/head gasket problem
or this is normal |
Worked for me......:-X22 You can load anything to YouTube if want.
Originally Posted by BLADE35
(Post 10221811)
or this is normal John thanks I know. i just dont remeber my youtube account. lmao |
Originally Posted by cheezit
(Post 10221830)
[quote=cheezit;10221830]30 pis in a cooling system is not normal. list to the engine rpm and watch the neddle rise and fall.
so 16 psi would be a good number what the cap is rated for??? |
cap is 16 psi. 16 is pushing it IMO .12 and under would be idea.
also this truck was cold too. ect/eot just about room temp. |
Ahhh... Yeaaahhh.... Reminds me of Powerstrokehelp.com video on youtube. He uses the same technique for diagnosing head gasket failures.
Ruh roh raggie!
Originally Posted by Troy Buenger
(Post 10222290)
(Post 10222445)
now thats funny. stay tuned ill add some more info later.
Gaskets? What gaskets? all I hear are jacuzzi bubbles.
