looking for wiring diagram color code
Can anyone tell me where to find a wiring color code chart for a 1970 F-350. Someone provided me with the wiring diagram but I am trying to find the chart that will tell me what color matches the numbers on the diagram. It would be much easier to trace wires if I knew the actual color each wire was supposed to be.
Take a look at this; the've pretty much mimiced the stock wiring diagram color code.
http://static.summitracing.com/globa...0540manual.pdf |
I'm trying to find a color code diagram for each pin on a 2008 ford expedition limited el radio harness with navigation and sync. I'm trying to connect the axxess aswc-1 harness for my steering wheel controls.
Check this out. I think this might be what you need.
https://www.ford-trucks.com/forums/1...g-diagram.html Hope this helps. |
Originally Posted by ldoggltm
(Post 18494966)
