Anyone with a Spyder Industries Headache Rack?
These look great:
http://www.spyderindustries.com/index.html My order from them has had some problems and I want to give them an opportunity to fix it. But I've discovered the F-150 rack is not mounted in the stake holes as advertised. I've been told the F-150 stake holes are too far forward and therefore the rack is mounted on each side with two bolts thru the bed rail mounting plates. This rack is very heavy and I'm concerned this won't be a strong enough mounting. |
Welcome to the forum.
I have moved this to the correct forum so you can get the best possible info. |
