DJM Suspension HS1123-4
have any of you used it? i wanted to get itbut the i noticed it says standard cab only on the summit website? im assuming this is a typo. makes no sensse as the single cab has no different suspesion set up than the ext cab. and the shackles that come in this kit say they work on both ext and single cab. yall think im safe buyin it? or should i just stick with the 2 inch drop :(
That should work , can't see why it would not....
Originally Posted by lew52
(Post 10190972)
Thanks man i went ahead and ordered the kit and shocks. i let yall know how the install goes i sure hope they work. can t imagine that a single cabs rear suspension hangers and shackles are any diffeent than that of an ext cab |
Only thing I could figure is the wt rating of the springs themselves would be heavier on a extended cab. (That's the case with the 4x4s in lift kits)
