DP Tuner and HID'S
I have had a major problem of the engine stalling or dieing every time i would turn on my HID's with the DP Tuner installed, truck would not miss a beat with the DP uninstalled.
I have 5 pairs of HID's installed, headlights (hi and low beam), 6- 6" Hid's in the bumper and now 2 6" backup lights and have tried all of the myths!! relays,grounds,passenger side battery, relocating ballasts, short heavy gauge grounds, heavy gauge power wire ect.ect... I learned to live with it and turn on my headlight before i start the truck.. (most of the time) big pain in the ass when you hit your hi beams and the truck dies and i would have to put it in neutral and restart while driving down the road. until today when i wired in two 6" Hid backup lights and tied them in so they come on when i put the truck in reverse, well guess what.. the truck died every time i put it in reverse.. It is the RF that is interfering with the unshielded ends of the F-5 cable allowing a large amount of RF to interfere with the PCM and IDM and killing the engine. I took the F-5 cable and installed 2 Ferrite beads on it right before it entered the PCM. Guess what? no more stalling. no ck engine light, no water in fuel light, no more anything. I can turn on all 5 pairs of lights at the same time with the truck running and not even 1 hickup at all. the Ferrite beads that i used are like these ones: FERRITE SPLIT BEAD, 7MM I.D. | AllElectronics.com http://i494.photobucket.com/albums/r...8/IMAG0306.jpg I have read several threads on this proble on several forums and have never heard of a absolute fix.. This works 100%. The added backup light is unreal from the Hid's Looking at backup camera before: http://i494.photobucket.com/albums/r...8/IMAG0307.jpg And After: http://i494.photobucket.com/albums/r...8/IMAG0308.jpg:-arrgh |
Great Fix. :-X22 What lead you to the ferrite suppression beads?
Reps sent and thanks for sharing. |
I use them in my line of work all the time on cat 5 cables to suppress RFI on wireless back hauls and wireless Access Points on transmission towers. after running a spectrum analyzer in the cab of the truck i found that as soon as i energized the HID's they omitted huge amounts of RF in a wide range of frequencies. Figured I would give it a shot and it worked!
I have these to install as well. Thought I had it fixed but fogs started making my abs light come on. Funny you posted this, I am installing mine tomorrow.
Originally Posted by milleroutdoors
(Post 10177834)
Originally Posted by Bergerson
(Post 10177788)
.... after running a spectrum analyzer in the cab of the truck..... huge amounts of RF in a wide range of frequencies.
I can see the new "Cold Start" Thread now: Are you clear in the 500GHz range? Great find and fix. Reps for the diligence. |
I've been dealing with this issue as well and while it was maybe 30% of the time, it's been enough of a concern that I would pull over to turn on my headlights so that I wasn't moving at all. I'll be ordering these later today if I can't find a pair in my stash of spares.
Great work, reps to ya! you should contact DP and share your fix.
I have the hids, am installing the beads. Thanks for your offer.
(Post 10178539)
Mark, what led you to the idea of trying the beads?? I haven't heard of anyone trying it yet? |
your pm's are full! Are those the exact size needed?
Originally Posted by WA.Ranger
(Post 10179615)
(Post 10180018)
E-MAIL me, satman8@gmail.com, and yes the ones I have work perfect. If u need 1 let me know, ill mail u 1.
(Post 10179112)
