6.0 running rough after fuel filter change
I have a 2005 PSD all stock minus a turbo back.After a oil change from the stealership and the fuel filter change at home the truck starts,idles,and runs like crap.Low on power ect...Fuel pressure was about 52 right off the upper fuel filter housing.Held there while i gave throttle. I checked with a infared heat meter on exhaust manifold on each cylinder exit and all seen to be running at similar temps,was told i could see if a injector was bad this way. Removed and reinstalled filters,no change...any ideas?I been searching but cant seem to find any answers. Oh,the stealership said it was air in lines and should go beat the snot out of it to remove the air? Sounds like they want a truck to come in w/ a blown head gasket.Any help much appreciated.Thanks in adavance,Adam.
If it ran fine before your filter change, I would say that you just have air in the system. Take it out and run it.
if it was running fine before the fuel filter change, I would say that you are probably sucking air from the filter housing. Did you oil the o-rings when you installed the caps? You probably have a pinched o-ring most likely the primary. I would try and change the o-rings and inspect the cap real close for cracks while you have it off.
On a side note...The techs that come on here that give us a lot of help don't apperciate being called a "steallership", and quite frankly I don't care for reading stuff like that either. You will get much more help around here if you don't use that term. |
I did oil the rings and ill check again,thanks for the info. The stealership reference was pointed directly to my local shop. I know there are great dealerships out there so i apoligize if i offended anyone,but the guys i have dealt w/ before are a little less than friendly. It does seem like an air intrusion but everytng looks good on the filter housings,but i will check again...at idle just a lil miss but if im driving and give her some pedal she wont downshift to go it just slowly accelerates in same gear.
Another question on this,is fuel pressure supposed to hold after you turn ignition on but not started? As soon as pump turns off pressure drops instantly,i can hear liquid running.I thought it would hold the pressure.Thanks...
My pressure drops pretty quickly when it is shut off.
Pressure drop
yeah i just installed a glow shift fuel pressure gauge on mine. I have 62 PSI with the BB mod and after bout 20 seconds mine pressure bleeds off. Its normal. I asked the local diesel master tech at ford. He has the same set up as us and had the same results. As for your possible air leak. Do you use a 1/2 ratchet on your fuel cap. I did on mine and it cracked around the ratchet point creating a leak. Couldn't see the crack until I put the ratchet in and twisted. Another possibility:D
There is a pinhole bleed port at the top of the fuel regulator through into the upper fuel filter housing. It bleeds a small amount of fuel off of the top of the filter housing into the fuel return line. It's purpose is to bleed air out of the filter housing, but it also causes fuel pressure to bleed off almost instantly after the pump turns off.
Originally Posted by AKPOWERSTROKE
(Post 10162749)
Amazon.com: Lisle 14500 Oil Filter Socket: Automotive |
Originally Posted by going up 2!
(Post 10158054)
I have a 2005 PSD all stock minus a turbo back.After a oil change from the xxxxxxship and the fuel filter change at home the truck starts,idles,and runs like crap.Low on power ect...Fuel pressure was about 52 right off the upper fuel filter housing.Held there while i gave throttle. I checked with a infared heat meter on exhaust manifold on each cylinder exit and all seen to be running at similar temps,was told i could see if a injector was bad this way. Removed and reinstalled filters,no change...any ideas?I been searching but cant seem to find any answers. Oh,the stealership said it was air in lines and should go beat the snot out of it to remove the air? Sounds like they want a truck to come in w/ a blown head gasket.Any help much appreciated.Thanks in adavance,Adam.
Yea i tried the key pump the first time and again after i took out filters to examine after issue came about,no difference...i will take a close look into all options stated by you guys again.thanks
(Post 10163432)
Not sure what you mean here, but FYI you must do the pump prime before you ever start it the first time. Otherwise it is too late and you have pumped bubbles through the line. Once you have done that, the only option is for them to eventually pass through the injectors. |
Originally Posted by bpounds
(Post 10163458)
(Post 10163497)
Super newb question but is the ok for the injectors to pass the air?
On the priming, I change the filters, and after everything is buttoned up, I turn the key to the ON position (engine off). Listen for the pump running and after 20-30 seconds it will turn itself off. Then turn the key OFF and wait 10 seconds. Then turn it back ON and wait for the pump to shut off again. Repeat 3 or 6 times, depending on the source. Only after that start the engine. I have never had a stumble following that routine. I also let it idle for a couple of minutes on high idle just to be safe. But I've never noticed a miss, so that might not be important. I do it so that if anything happens it will be in my driveway and not out in the street. |
Well i hope air is easier to pass than a kidney stone.Ill def keep the prime trick in my head for next time...thanks all again,Adam
