99-03 7.3l parts
All prices are plus shipping.
Please PM me if you want to negotiate a price or want ask questions about a part. Posting here if highly interested only, id like to keep the thread quick and clean:thumb: I will keep the thread updated, if its listed then its available. late 1999- 2003 7.3 powerstroke parts. All parts have under 200k on them, some have as little as 120k. Split shot injectors, good shape out of running engine- 2 sets- $350 ea Fuel bowl assembly- 2 avail.-- $75 ea Valve cover gasket+wiring harness--2 sets avail.--- $75 ea 17* Hpop w/IPR -- 1 avail.--- $250 Cylinder Heads--2 sets avail-- $250ea Exhaust Manifold--2 sets avail.--- $100 ea 3" intake plenum w/boots-- 2 sets avail.---$80 ea stock cam w/lifters---2 avail.----$150 ea Hpop resevoir--2 avail--$40 ea Valve covers w/ bolts---2 sets available---$60 ea CPS sensor-- 2 avail--- $25 ea ICP sensor--2 avail--- $80 ea EBPV sensor- 2 avail-- $25 ea block heater- 2 avail-- $35 ea Oil pan (perfect condition)--2 avail-- $50 ea Turbo pedistal w/up-pipes --2 available--$150 ea Intake spyder (not e99)- $65 LPOP--2 avail-- $75ea glowplugs--2 sets avail.-- $40 ea front cover--2 available-- $90ea push rods--2 sets avail.--$40 ea Forged Rods--2 sets available-- $200 ea |
Intercooler available??
Originally Posted by snaponprofile
(Post 10151274)
I responded, dang pm inbox fills up so fast, lol.
Hello, Looking to get a fuel bowl assemble or more specificly the fuel return fitting that bolts to the fuel bowl and allows the return tube fitting to thread on to it. Do you still have one available?
99 f250 7.3 PSD. |
Replied where necessary!
No i dont have any IC's available at this time, but i may in the future. Im always at the junkyard! |
Does that mean the IC is normally a seperate part from the fuel bowl assembly?
It is the back pressure control port I believe. If you could find one do you have an idea of the cost? (no shipping included). I hope this was not a problem with where this got posted I did not see where to pm you. |
Originally Posted by whalermark
(Post 10156319)
It is the back pressure control port I believe. If you could find one do you have an idea of the cost? (no shipping included). I hope this was not a problem with where this got posted I did not see where to pm you. The "IC" i was referring to was for someone else, they mentioned an intercooler (IC) |
I need to intercool my obs. I cant find an early 99 intake spider. Can I update the manifolds that bolt to the head and use the newer spyder. If so do you have all the parts i need aside from piping of course. If so how much? Thanks
Originally Posted by pro5.0
(Post 10165945)
Has anyone heard from the host of this thread?
STROKEORCROAKE where are you? :-wink |
A simple PM to him would do.;)
Did that-no reply. I'm sure he will get back, I'm just a little anxiuos is all. Trucks been down since Thanksgiving, finally got the money to fix it and all that I need is that last part. Kinda like christmas Eve, I'm sure you can relate.
Thanks |
Bump bump bump
Sorry it did not workout for the transaction, hopefully UPS can figure out where to pick the part up for delivery, save grandmom the hassel of the Post Office.
Good luck in the future |
