2000 F350 single rear Axel swap to Dually Axel Question
Guys i have 2000 F350 Single Rear Wheel .I want to convert it to Dually.I have found1 guy who has 2001 F350 dual rear axel complete with brakes.
So my question is will it work if i swap my axel with dual 2001 axel. Also is 2001 & 2000 axel same.Please let me know.Thank You |
any1 got any clue?
Send me some measurements, mine is a late 99 dually, ill check and see if its the same,somewhere on fte I saw a post with super duty dimensions
Yes you can swap them out. The F-350 dually all have Dana-80 rear ends. Your SRW has a Sterling 10.5 rear end. Just make sure you have the same gears in the front that is in the rear.
Originally Posted by miller_feed
(Post 10107675)
But i am not sure what gear are you talking about & how do i check.Can u pls explain. thx |
Also i am getting the complete dually axel with wheels for $400.Is it good price.let me know.thx
Originally Posted by idesign
(Post 10107751)
thx for reply
(Post 10107762)
(Post 10107836)
I'm talking about the ratio, 4:10, 3:73, or what ever. If you have 2wd then don't worry about this.
You are talking about changing the whole differential, not just the axles? what should i ask him.let me know.thx can u pls list what things are needed to convert my truck to dually.i wana make sure i get everything from the guy.thx |
What is your motivation for swapping to a dually, and do you have a dually box located already?
(Post 10107836)
Originally Posted by cartmanea
(Post 10107994)
Sounds like the whole axle assembly to me. Not sure why you would question otherwise, I can't see someone trying to put axle shafts from a D80 in a 10.5...
I hope the D80 has the leaf springs with it and the 4" blocks. |
