Ford Truck Enthusiasts Forums
-   1948 - 1956 F1, F100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum41/)
-   -   Installing Mustang II front end in my 55 F100 (https://www.ford-trucks.com/forums/1049138-installing-mustang-ii-front-end-in-my-55-f100.html)
Gibby55 03-12-2011 08:00 PM
My setup is from CPP. I went with the 2" drop spindles and the air bag setup and I am going to weld in the cross member tomorrow and I was curious what others have done to find there "ride height." Im just looking fow what others have done and tried before I make a mistake someone else has already made. My hardest dicision is finding my ride height so that I can level my cross member.
sdetweil 03-12-2011 08:05 PM
I have always heard that the bottom of the front bumper should be barbie doll height.. 11 inches.
hoping my MII kit arrives this week.
Sam
BBKtech2 03-12-2011 08:46 PM
It's all preset in the cross member. Just weld it in. It will sit fine, especially with the 2" spindles. If you want it slammed when the bags are drained, notch the frame an 1" and install the crossmember. I've used CPP's kits for years, quality stuff.
BBKtech2 03-12-2011 08:50 PM
hoping my MII kits arrives this week.
Sam
With the Mustang II kits out, you won't get the bottom of the front bumper to sit at 11". Usually it ends up with the TOP of the bumper in the 10-11" range.
Old F1 03-12-2011 09:53 PM
Originally Posted by BBKtech2 (Post 10087025)
It's all preset in the cross member..
.................................................. .:-X22:-X22:-X22:-X22:-X22
BACAGrizz 03-12-2011 11:31 PM
I have the Heidt's cross member and with the Wilwood Pro spindle stock height spindles the bottom of my front bumper is 6" for the ground.
You need to decide how you are going to set up the rear end first. Then set the x-mem so it is level with the ground.
sdetweil 03-13-2011 06:31 AM
ok, TOP of the bumper at 11!..
Sam
Gibby55 03-13-2011 04:52 PM
Any one have any pictures as to where they welded the upper shock tower and there bump stop for the airbag setup. Most of the write ups i look at either do not have pics or the pics have been deleted.
