picture of magnesol pump
anyone have a pic of this..mine decided that it dosent want to work. i have it on the floor with a 8 ft hose in the tank, and a hose going to the filters...wont work...
just looking for a pic. thanks guys |
my pump is a diaphragm pump from dudadiesel, was about $100. I need to get out tomorrow and update pics...
Originally Posted by Philip Berardi
(Post 10083948)
Fabman- I understand that. I am just trying to figure out how uguys pump ur bio off the top. My pump wouldn't get suction. Just wanted to see what u guys used
I use an air powered diaphragm pump.........
Pictures :) and I am tyring to figure out how I can put a lot level strainer on tjhe bottom to put thje hose in there and let it rest on the magnesol but not suck it up. Where did u get the air powered pump?
(Post 10086708)
This is the type of air powered pump I use: http://i51.photobucket.com/albums/f3...ux/7400013.jpg |
(Post 10086708)
Sandpiper Air-Operated Double Diaphragm Pump 1/4in. Inlet, 15 GPM, Polypropylene/Buna, Model# S05B2PBTPNS000 | Air Operated Oil Pumps | Northern Tool + Equipment Your local truck supply (TruckPro) should have it...or know who would have 'em. |
i just dont get how you are using that with the magnsol and not picking it up off the bottom.
i was planning on getting the pump from dudadisel and connecting 3/4" hose to it and sucking the finished product essentially off the magnesol, when i saw the magnesol i would stop. is that what you guys do? just seems like a lot of work. |
have it hooke to a pvc pipe that I lower to above the level of the magnesol. Per another suggestion, I am going to make a p-trap on the end so it draw down rather than up....
