gauge cluster swap...
hi i want 2 swap a gauge cluster w/ a tac into my '96 F-150 from a '96 Bronco how hard is this and can anyone out there that has done it tell me the procedure thanks
P.S. why didn't F-150's come with a tac but Bronco's did |
Not all Broncos did. My 94 Bronco with the 302 and a 5 speed had no tachometer, which I found odd being that it had a manual transmission.
As for your actual question, I'm not sure. I would assume plug and play, but I'm probably assuming wrong. I'm sure some smart person will show up soon and teach us both. xD |
I switched the gauge cluster from my 94 f150 to my 95 F150 and it was plug and play. The swap is simple. I kept the same PSOM from the 94 since the mileage was close but you can change that part if you want to keep the same mileage reading.
Many F 150s came with the tach. My 83 and 94 XL had them and my 92 Custom and 95 XLT did not. Regards rikard |
Originally Posted by rikard
(Post 10060708)
Yes a lot of them did, my 1995 F-150 302 came from the factory with a tachometer.
My 94 460 did not come with a tachometer. The 96B to 96F should be plug and play. |
Funny you should mention a gauge swap... I was just out working on the F350 and snapping some pics of the dash removal.:-X07
Anyways, it is a plug and play swap, not too awful bad, but does have a couple steps involved.
hey thanks bud that was very descriptive... helped me out a lot now i don't have 2 go at it blind....
i got the cluster with a tac in that 92. so the f 150 did have them on some models.
Originally Posted by USMC0351fordtruckin
(Post 10061079)
Originally Posted by L. Ward
(Post 10061090)
Happy to help!
so the new cluster with a tach does it need any new wires or is the wire for the tach already their and hooked up
(Post 10060637)
Originally Posted by deljac
(Post 10061145)
i just did this swap on my 1996 f-250, with a 460. I picked up a tach cluster off e-bay for 30 bucks. it came off a 1996 f150. It was real easy just plugged right in and everything worked great. I think you need to get one from the same year so all the lights and everything work. If you dont you have to do some modifications. to the circuit board. it's now like driving a brand new truck.
