"Roxy" 1974 Ranchero 500 build
http://i147.photobucket.com/albums/r...0908101659.jpg http://i147.photobucket.com/albums/r...908101659c.jpg http://i147.photobucket.com/albums/r...0908101658.jpg This is my 1974 ranchero I picked up for 1000 bones. She sat in a field for 9 years untouched. I trailered it home, changed the plugs, put a battery in it and had the tank douched. Fired right up. Still has a 351C, but I have a old 460 D0VE-A block with D0VE-C heads getting the once over. Last year I tore her apart and started the tedious rust restoration. And lost intrest. Well Im untarping her and dragging it back into the shop to finish up what little rust is left and slap on some paint |
I have a couple paint schemes Im debating on.
metallic blue with silver stripes flat black Silver with a gloss black raceing strip, blacked out wheels Im leaning towards the last one but I enjoy hearing other opinions |
I should be getting my sheet metal Monday to finish up the exterior body work
Not bad, but I'm not a big fan of black since it shows every speck of dirt. The same pattern in 69 acupulco blue metalic would be nice. Looks like a fun project.
I was going to do metallic blue but its just not agressive enough
Of the color combos you listed, I'd go with the blue/silver. But it's your truck. Gotta make yourself happy.
I used a longer version of that hood scoop on my '74 GT- saddle bronze with an orange GT stripe. When I added the scoop, I had about a 2" orange stripe outlined in black painted above the line of the scoop. I needed the scoop to cover the hole in the hood for the tunnel ram. Do not try to mold in the scoop. They will all crack. Leave it as a bolt on. I had 1 scoop with a the hole for the tunnel ram, and replaced it with one without the hole when I switched to a very rare 429 CJ 3 two barrel intake. The drivetrain was a built .060 over 460 (472), 429CJ 3X2 intake, C6, 3.50 rear gears. Been sitting for 6 years after the timing chain broke. Too rusty to spend much $$ to fix. And no, the intake is not for sale at this time. |
3 duces would be bad A.
But Im sure when and if you sell them I wouldnt be able to afford them anyhow haha. Im sure they are alot of tuneing to |
I vote black and metalic silver strips or the other way around. If you need help with this, I am learning to paint this summer. Also you should turbo the 460. I know pretty much everything, and what parts can get you there for the least amount of money. I'll get ahold of you later today to talk. haven't been on in months. I could help with fab work. I am doing the welding classes at FVCC right now.
I need help
Black and Silver:
http://i147.photobucket.com/albums/r...ntconcepts.jpg Black and Blue: http://i147.photobucket.com/albums/r.../blueblack.jpg |
Up till 5am kicking ass and taking names on the body work, re-assembling the front getting her ready for paint next week :D
http://i147.photobucket.com/albums/r...0317110444.jpg http://i147.photobucket.com/albums/r...0315111710.jpg |
update
Quick Q. Are you going with the 74 "battering ram" bumper, or are you going to use the more aero 71-72 style?
