90 F-250 Radio install
I bought my truck with no radio so i will be in need of installing one its been 3 months and now i cannot take it anymore if anyone has a ideas on what will make it easier and what wires connect to what type it would be greatly appreciated thanks!
You can get install kits from most of the same stores that sell auto stereos that will match the wiring harness in your truck complete with mounting plate that will match the cut out in your dash,pretty much plug and play,don't make the mistake of cutting any wires.
^^ as he said would be the solution if the wires have NOT been cut.
If they have, you need to get a volt meter and see which wires go where. one wire should always be hot (aux) and one only is hot when the key is on (power) and a ground. If those are all wired up right, your radio will turn on. then you need to figure out which other wires go to the speakers. Usually, they are color coated. such as black and black/white. violet and violet/green and so on. |
