HELP! No Driver Lowbeam! 07 expy
Driver side lowbeam has no power running to it on '07 expy.
I checked and replaced fuses for both passenger and driver lowbeams. The highbeams work for both sides! And Ideas? |
Do you have power to the fuse?
Replace the driver side bulb. Likely the low beam filament is burnt.
Forgot to mention that I replaced the bulb with 2 others...it was how I determined that there was no power to the low beam...
Someone mentioned that I should check the SBJ (subjunction box?) for power, but I have no idea where that is... |
Maybe the bulb connector?
Had the same problem before when i replaced mine with HIDs. :confused: took my truck to the dealer and they said my headlight switch is the problem. :-arrgh they replaced it and now it works :-X22
