turbo question
hey guy i got a small problem with my turbo project i was wondering if anyone could help. ive posted this problem on 2 other forums and no body has answered.
Well, this forum isn't the most highly traveled, but we ya won't know if we can help until you post your question, doncha think?
Make sure you tell us what kind of truck you have, year, engine, model, mods, etc along with your question. Your best bet is to probably find a forum who's members have done a lot of turbo work with whatever kind of truck you have. What other forums did you post to? Stewart |
yea i didn't want to type it all up again and not get a response. anyways the truck is a 2007 4.2 (4.3 now) i completly built the engine minus block and crank. I am getting ready to buy STS remote turbo system. the only thing i am having a problem with is locating the corrector fuel injectors and fuel pump. I know what size injectors I need but i dont know which will be compatible with my engine. same goes for the fuel pump i found walbro 255 universal one, but its just the pump no wiring or anything. with the pump what would i need to do to get it to function. and which injectors are correct here is the injectors and pumps i was looking at.
http://treperformance.com/i-6321439-...2004-2007.html i dont know anything about this company. do they have a good rep and are their products good. once again this is justhe pump, no wiring, ect http://cgi.ebay.com/ebaymotors/6-For...Q5fCarQ5fParts will these work? http://www.summitracing.com/parts/VPN-GCA719-2/ walbro for a 4.6 mustang. will it work yay or nay |
The walbro should work I have seen people use them on gm's doing similar things.
As for injectors any should work as long as the impedence is the same and overall length. I remember seeing how lots of gms and fords use the same injectors. |
You should consider increasing fuel line size if its to small while your at it.
what about those injectors i found on ebay, i have no idea what i'm looking at im not savy with this sort of stuff. i posted the link earlier but here it is again 6 - Ford 60lb High Resistance Fuel Injectors NEW SET - eBay (item 370458394959 end time Mar-19-11 23:56:14 PDT)
Originally Posted by strattonv6
(Post 10019111)
Also, who do you plan on using to create your custom tunes to run your truck? Whomever you've decided to use, you should ask them for input too. Stewart |
