Ford Truck Enthusiasts Forums
-   1999 - 2003 7.3L Power Stroke Diesel (https://www.ford-trucks.com/forums/forum31/)
-   -   Ball joint tools (https://www.ford-trucks.com/forums/1043809-ball-joint-tools.html)
nitro3421 02-24-2011 09:20 PM
Ball joint tools
I also posted this question in the general Superduty section, but would like to get your guys' opinion as well...
I'm trying to make sure I have ALL the necessary tools to complete my upper/lower ball joint replacement. Here is everything I think I will need:
-3 Jaw pullers for hub & sway bars:
4 Piece Three-Jaw Puller Set
-Ball joint press kit (Do I need a special Ford adapter for this particular kit?):
Four Wheel Drive Ball Joint Service Kit
Possibly this OTC adapter (Do I absolutely need this? I'd rather not spend an additional $60):OTC Tools 6731 - OTC Ford Ball Joint Adapter Upgrade Kits - Overview - SummitRacing.com
-Pickle forks:
Grip-On Tools 5-Pc. Pickle Fork Kit, Model# 21318 | Ball Joint, Bearing + Gear Repair | Northern Tool + Equipment
Out of the ordinary sockets:
-1/2 drive 33mm socket
- 1/2 drive 21mm socket
- 1/2 drive 13/16" socket (for ball joint press)
- 1/2 drive 1-1/8" socket
-Home made knuckle seal tool:
Ford Super Duty Knuckle Seal Tool - AKA OTC 6695 | Superdutypsd.com
-Beefy impact wrench. It's time for me to upgrade, and was hoping to find a good used one on ebay. Any suggestions (make/model #)?
Anything else?
RNH Performance 02-24-2011 09:45 PM
you can rent the master front end suspension toolkit from advanced auto it has the short sleeve you can use for the ford.
replacr your hub o rings n check for vacuum lines for the 4 wheel drive. I also service the needle bearings....
White 99 02-24-2011 10:03 PM
I am not sure what I was trying to seperate but of the size but my largest pickle fork was not wide enough when I did mine. I would look for the largest one I could find. Maybe someone else has a source for the correct one.
bcaughhorn 02-25-2011 04:46 AM
i havent done the ball joints on my f250 but on all the other ball joints ive done i didnt use the fork. i turned the wheel to one side and hit the spindle (rite at the ball joint) with a 3lbs hammer. if they have tension on they they usually come rite out
lhud 02-25-2011 06:44 AM
NITRO,
Take one of your ball joints (lower is largest) and see which pickle fork fits that one.
I purchased some time back the IR impact: 1/2" drive with 1000 ft-lbs torque; Mdl IR2135QTIMAX.
It is light weight and a strong tool.
The Advance Auto kit (large one) will have all the required sleeves.
Not a bad job, but a little time consuming and some grunt work.
Very satisfying considering the money you will be saving.
Ziggy. 02-25-2011 07:09 AM
It's not too bad of a job. I've got it down to 1 1/2 to do 1 side from start to finish. I don't use the ball joint press, I've got a round stock piece I hardened to use as a punch, and an old worn out 3/4 impact socket I had that I used to just punch the old joints out, all of the ones i've done so far came out pretty easy. The only thing I usually run into a problem with is getting the knuckle loose, I usually put a pickle fork on it to keep some tension downward on it, and beat it off with a 3lb sledge.
As the others mentioned It is a good time to service the needle bearing and vacuum hub.
You will also need a large set of snap ring pliers, The ones with the round tit on the end, not the flat end ones, for the snap ring on the axle shaft.
nitro3421 02-28-2011 08:21 PM
Anyone want to sell me their homemade seal press? No where locally sells 1-1/4" threaded pipe, a flange & cap. I would gladly pay $20+ shipping...
nitro3421 02-28-2011 08:23 PM
Originally Posted by lhud (Post 10016220)
NITRO,
Good call on the IR. I found a 244a used on ebay for $45, should be a great impact gun.
I'm just hoping I dont have to pay someone to do this. I only have a week timeframe to do this on a busy schedule between when I get the parts & when I'm leaving for a 3000 mile road trip...
timmyboy76 02-28-2011 08:30 PM
thats how i roll bud, but if your not try'n to "save" the ball joints, guess the pickle fork will work then.
onelionhunter 02-28-2011 08:45 PM
Seal tool
Where are you located, maybe someone close by has the home made seal tool?
nitro3421 02-28-2011 08:48 PM
I'm in San Luis Obispo, CA. I'm also open to the idea of paying someone to do this job if anyone here wants to make a few bucks.
onelionhunter 02-28-2011 09:40 PM
Bit far
Bit far for me, but I know we have alot of members in CA, hope someone is nearby that can assist in one way or another.
© 2018 MH Sub I, LLC dba Internet Brands
