Ford Truck Enthusiasts Forums
-   Excursion - King of SUVs (https://www.ford-trucks.com/forums/forum29/)
-   -   MAF (mass airflow sensor) cleanup day (https://www.ford-trucks.com/forums/1042133-maf-mass-airflow-sensor-cleanup-day.html)
wpnaes 02-20-2011 12:33 PM
3 Attachment(s)
In between sneaking peeks at the Daytona race today, I'm cleaning the MAF. In case you haven't done this, here's a quick pictoral.
1. pop off the air filter housing
2. oops, pull out the key, disconnect the battery
3. pop off the MAF assembly from the filter housing with a screw driver (gently)
wpnaes 02-20-2011 12:38 PM
3 Attachment(s)
4. disconnect the wiring from the sensor.
5. place it on a workspace and get out the spray.
6. Spray sensor thoroughly.
wpnaes 02-20-2011 12:43 PM
3 Attachment(s)
7. Let it all dry well before reinstalling.
8. If you run an oily airfilter, clean it up while you're in there.
9. Don't over oil or you'll be doing this again soon.
VONxRUBENxLA 10-11-2011 07:26 PM
This is great thank u!!!
wpnaes 10-11-2011 09:23 PM
From the Future:
Originally Posted by jh818 (Post 10910470)
Make sure you disconnect the negative terminal on your battery before you begin. Don't want to accidentally short something. Plus, it will be long enough for the computer to reset and relearn your druving pattern with the cleaned MAF sensor.
Thanks John!
CrzHelm 10-12-2011 07:12 AM
in past 2 vehicles i damaged 2 of those mass air sensors from using k&n oil type filters. between the cost of the k&n, new air sensors, and oil cleaning kit, I would never recoupe the money spent in trying to save 1or2 mpg. just by the cheapest air filter every year and you'll be better off.
CrzHelm 10-12-2011 07:16 AM
and to those who insist on using the oil... just keep your old cheap filter to use for a day or 2 while your filter soaks up the oil. trick is very little oil and let it sit at least a day or 2. if you try to spray it all up to make it look red your gonna wind up with problems.
jasonodsky 01-24-2012 12:14 PM
Thanks wpnaes! The pics made the job really easy. Had some dirt built up on there and now have as smoother idle. Truck just sounds happier.
Thor2911 02-12-2012 04:14 PM
Thanks for the post on this issue. I purchased my X with the K&N filter on it. I am going to clean it today and hopefully not over oil the darn thing. Should I clean the MAF sensor on a regular basis? :-huh Thanks
wpnaes 02-12-2012 04:24 PM
I clean it once a year. I clean the K&N every 6 months or so.
Stewart_H 02-12-2012 04:57 PM
Thread added to the tech folder.
Stewart
wpnaes 02-18-2012 10:48 AM
Thanks Stewart.
JWA encountered this issue while cleaning, I thought it might come in handy for others: (Thx JWA!)
:-X22
MAF Cleaning
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->Noticed your great post about MAF cleaning---nice photos, makes it easier for those never attempting this operation.
I also did this but encountered a minor problem with the pressed-in threaded inserts that hold the sensor in the intake tube. Photos here:
http://i184.photobucket.com/albums/x.../AirDuct88.jpg
http://i184.photobucket.com/albums/x.../AirDuct89.jpg
http://i184.photobucket.com/albums/x.../AirDuct11.jpg
If these would be useful to include in your post and/or tech folder please feel free to use them. This might not be a common thing but might be helpful to know in advance it can happen.
J W A
jh818 02-18-2012 10:55 AM
That sucks. Super glue should do the trick.
myblkex 04-17-2012 06:33 AM
Originally Posted by wpnaes (Post 11451085)
Thanks Stewart.
:-X22
MAF Cleaning
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->Noticed your great post about MAF cleaning---nice photos, makes it easier for those never attempting this operation.
J W A
Some Great info here -- Just what I was looking for. Gonna clean mine this weekend :-jammin
king-david 07-09-2012 09:20 PM
Can someone tell me where the MAF sensor is on my 02 Excursion with a k&n cold air kit on it? I don't see anything resembling the picture in mine...
