1964 Ford F100 Steering column and gearbox
Just bought a 1964 ford f100 and pretty much the only thing it needs is a new steering column and gear box. Any one know where I can get one. This is my first ford so I'm a little lost on where to get quality parts for it. Any help is appreciated.
http://signatures.myarmedforces.com/..._signature.png |
Why does it need a column and steering box. Describe the means and it may be other things exasperating the issues.
Expect to pay 4 to 500 for a rebuilt box. The column can be rebuilt with available parts from ford or aftermarket. Garbz |
While obsolete, all the internal parts of the M/S gearbox can be found NOS. Sometimes, only the steering shaft's bearings/races and sector shaft bushing need to be replaced to correct the 'play' in the wheel.
The upper/lower steering column bearings (2-C3DZ3517A) and sleeves (2-B1AZ3518A) are still available from Ford. Both the 3 speed manual & A/T shift collars have been reproduced. If a 3 speed M/T, and the shift lever is binding up between 1st & 2nd, the parts (bushings/insulators) to fix this problem can also be found NOS (New Old Stock). |
Somebody replaced the original steering column and gearbox with a newer model and it is WAY to long. I'm practically driving with my chest. Was looking for the original or one of very similar lengths. Sorry I wasn't more specific originally.
Originally Posted by connvicted64f100
(Post 9990180)
Here is a link : https://secure25.securewebsession.co...shop/index.htm Give them a try! :-X0A6 |
You need to dive a bit deeper in to the truck and confirm it is a 64. Is the truck a Twin I beam or a straight axle?
Post the vin number. The 61 to 64 steering box is an integral shaft type and nothing else remotely fits unless it was upgraded with a Toyota conversion. Garbz |
Can you elaborate a little more on the Toyota conversion? I'm stationed in Germany and the truck is with my dad as he is doing all the work for me while I am over here.
power steering
Hello, I was wondering if you were able to do the Toyota conversion for power steering on your 64 F100 and is so would you please share the details. I would really appreciate it.
Thank you, Tyronza |
