732t37 |
02-15-2011 10:02 PM |
To answer your question: If you have a 91+, lean over the RH fender and trace the fuel rail back to the firewall and you should find a Schrader valve, like a tire has. Stick a 1/8" or smaller cabinet screwdriver in it to bleed off whatever is clogging your fuel line, the screwdriver that comes with a chainsaw for adjusting the carburetor works great. On a side note, your truck should start even with air in the fuel line as long as you crank the engine for 10 seconds or more. Quick diagnostic check that takes less than 20 minutes: Turn the key to "on" but DO NOT crank the engine, then turn it off. Disconnect the fuel filter on the gas tank side and see that fuel sprays out. Leave the filter disconnected, jump the "fuel pressure test" pins on the EEC test connector near the brake booster, then leave the key on as before while watching the fuel drain into an old soda bottle and see that it fills it up to 20oz in 10 seconds or less. If your truck fails either of these tests, you have a bad fuel pump or a leak in the lines or regulator. Check the regulator, then eliminate a leak, then make sure the fuel pump is good. If the truck passes BOTH of these tests, you have a problem other than the fuel system and I wish you the best of luck.
