Stereo wiring harness colors
Can someone confirm if this is correct? Appears to be for Excursions at least 2000-02?
2000 Ford Excursion Car Stereo Wiring Schematic Car Radio Battery Constant 12v+ Wire: Light Green/Violet Car Radio Accessory Switched 12v+ Wire: Black/Pink Car Radio Ground Wire: Black Car Radio Illumination Wire: Light Blue/Black Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): Dark Green/Orange Right Front Speaker Negative Wire (-): White/Light Green Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink |
Not sure- I've always used a harness so I don't have to cut the stock wires.
Usually the12volt.com has accurate info- I'd check there. |
I think that info is from the 12volt forum.
Same info that I got form there. My stereo is due in on the 14th, so I can confirm a few days after for ya, that is if the weather cooperates. Hafta wire mine outside parked in the driveway. |
Airslot - PM me and i will send you the factory wiring ofr the 2002. It is also posted in my gallery but you may not be able to read it.
Originally Posted by TXSailor
(Post 9762824)
<TABLE dir=ltr border=0 cellSpacing=0 cellPadding=2 width=359><TBODY><TR><TD height=19 width="62%" colSpan=3>Ford Harness connector </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">Use </TD></TR><TR><TD height=19 width="19%"> </TD><TD height=19 width="23%"> </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%"> </TD></TR><TR><TD height=19 width="19%">Pin </TD><TD height=19 width="23%">Color </TD><TD height=19 width="19%">ID </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%"> </TD></TR><TR><TD height=19 width="19%"> </TD><TD height=19 width="23%"> </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%"> </TD></TR><TR><TD height=19 width="19%">1 </TD><TD height=19 width="23%">Lt Blu/Red </TD><TD height=19 width="19%">19 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">Illuination </TD></TR><TR><TD height=19 width="19%">2 </TD><TD height=19 width="23%">BLK </TD><TD height=19 width="19%">57 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">Ground </TD></TR><TR><TD height=19 width="19%">3 </TD><TD height=19 width="23%">Red/Blk </TD><TD height=19 width="19%">1000 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">Ignition </TD></TR><TR><TD height=19 width="19%">4 </TD><TD height=19 width="23%"> </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">blank </TD></TR><TR><TD height=19 width="19%">5 </TD><TD height=19 width="23%">Org/Red </TD><TD height=19 width="19%">802 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">RR Speaker </TD></TR><TR><TD height=19 width="19%">6 </TD><TD height=19 width="23%">Brn/Pnk </TD><TD height=19 width="19%">803 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">RR Speaker </TD></TR><TR><TD height=19 width="19%">7 </TD><TD height=19 width="23%">Wht/Lt Grn </TD><TD height=19 width="19%">805 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">RF Speaker </TD></TR><TR><TD height=19 width="19%">8 </TD><TD height=19 width="23%">Dk Grn/Org </TD><TD height=19 width="19%">811 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">RF Speaker </TD></TR><TR><TD height=19 width="19%">9 </TD><TD height=19 width="23%">Lt Grn/Vio </TD><TD height=19 width="19%">797 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">Power </TD></TR><TR><TD height=19 width="19%">10 </TD><TD height=19 width="23%">Blk/Pnl </TD><TD height=19 width="19%">194 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">Ignition </TD></TR><TR><TD height=19 width="19%">11 </TD><TD height=19 width="23%">Blk/Lt Grn </TD><TD height=19 width="19%">694 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">Ground </TD></TR><TR><TD height=19 width="19%">12 </TD><TD height=19 width="23%">Gry/Lt Blu </TD><TD height=19 width="19%">800 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">LR Speaker </TD></TR><TR><TD height=19 width="19%">13 </TD><TD height=19 width="23%">Tan/Yel </TD><TD height=19 width="19%">801 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">LR Speaker </TD></TR><TR><TD height=19 width="19%">14 </TD><TD height=19 width="23%">Org/Lt Grn </TD><TD height=19 width="19%">804 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">LF Speaker </TD></TR><TR><TD height=19 width="19%">15 </TD><TD height=19 width="23%">Lt Blu/Wht </TD><TD height=19 width="19%">813 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">LF Speaker </TD></TR><TR><TD height=19 width="19%">16 </TD><TD height=19 width="23%">Blk/Lt Grn </TD><TD height=19 width="19%">694 </TD><TD height=19 width="19%"> </TD><TD height=19 width="19%">Ground </TD></TR></TBODY></TABLE> Just leave your RICP (Rear Console Control Panel) plugged in and you may be ok for the Rear speakers. Worse case is some jumpers in the connector of the RICP. Like I said, if you PM me with an e-mial address, I'll send you the wiring diagram. BTW - The speaker wires are in the Passenger Front Foot well (Right side) and not the Drivers side. As far as the Steering Wheel controls, Pin 14 of the 20 pin Ford connector ( that plugs into the back of the Ford CD/Radio) goes to the Steering Wheel Controls. It is a Lt Blue/Red wire. Connect it to Key 1 (Red wire or #9 on your radio diagram. You will probably have to ground the other radio Steering Wheel control wire ( #12 or Key 2). According to the manual on my radio (which showed up yesterday), these may need to be reversed to work. I did power up my radio and check all the functions and everything works. Just need to mount it in the EX Dw |
Question about radio install
Hi. Could you send me a picture of the wiring scheme for the steering controls? I have an 03 Ex and bought an aftermarket Chinese double din stereo. Thanks in advance.
Originally Posted by ddorband
(Post 9950917)
TXSailor posted this on a different thread, it is what I used when I did my install of an aftermarket head unit a few weeks ago. I found that it matched my Ex (2002 7.3 Limited) perfectly. There is also an additional plug in the back of your stock head unit, my understanding is that is primarily for the rear audio controls, and steering wheel controls, which I do not believe you have in a 2000. My new head unit did not have the ability to have a separate rear zone, so all I used out of that harness was the Lt Blue/Red wire for the steering wheel controls.
