Ford Modular V8 5.4 2V SOHC Triton Parts (Heads/Sensors/Flexplate/Harnesses/Oil Pan)
Parting out a 1997 Ford 5.4L V8 NPI Modular motor out of an F150 (Windsor casting)... Had 257k on it; did not smoke and burned no oil... engine ran great, but was developing a rod knock. Tear-down revealed worn rod bearings.
Upper 5.4L Triton plenum w/EGR valve --- $20 5.4L Triton throttle body --- $20 https://img.photobucket.com/albums/v...t/DSCN6920.jpg 5.4L knock sensor --- $10 https://img.photobucket.com/albums/v...t/DSCN7264.jpg Crank and Cam sensors, 4.6L / 5.4L, working condition --- $10 ea. 5.4L alternator, 130 AMP, excellent working condition, tested good output (need to swap your pulley) --- $40 https://img.photobucket.com/albums/v...t/DSCN7550.jpg 5.4L Fuel pump, unknown mileage, works great. --- $20 5.4L EGR tube, less then 5k miles, bought new (over $75) from Ford --- $30 https://img.photobucket.com/albums/v...t/DSCN7551.jpg 1997-98 Ford 5.4L engine wiring harness, complete and in near perfect shape (F150 & Expedition); may fit other years - $75 https://img.photobucket.com/albums/v...150Harness.jpg Triton 5.4L Vacuum harness, excellent condition --- $20 Feel free to inquire with other needs or make offers; may be able to ship. PM me with any questions. Thanks! |
Bump... Updated.
what are the casting numbers on the heads?
where's the block and crank?
Block and crank were sold. Never checked the casting numbers; they are NPI heads.
