My Ex rolls in park?
I went to park my 2000 excursion today and I was just about to get out when I noticed I was still rolling as if I was in neutral. I quickly shifted back into park and it finally stopped, but it seems to keep happening. If I dont really push up all the way in park, it wont catch the parking pawl. Is there an adjustment I can make to fix this? I dont want my mother who usually drives it to have any trouble with it and it has happened to her already. I appreciate the help.
What's probably happened is a small bolt fell out under your steering column. Check on the floorboard before you kick it out. Lay on your back look straght up at the steering column. there's a bracket that looks simular to a pipe clamp. It has two bolts about 1.5" apart. Check them for tightness.
I was thinking the shifter cable may have stretched.
This is a common problem
Originally Posted by jeeplj8
(Post 9909850)
It's not my old one is it???
