PCV Valves on F53 Motorhomes
MY 2003 Class A motor home has the 310 HP V-10 vin "S". for the las few years I have been having a problems with oil being suck up the PCV line and into the Plenum and it is using/sucking oil and when started after a few days there's a white puff smoke,,clearly it's coming from the PCV as the lines are oil soaked even into ther Plenum I can feel the oil. Has any else had this problem, especially with the ford V-10. Otherwise I really enjoy my motorhome and the V-10 has great power and torgue. I have had no other problem with this unit. Any suggestions?
I getting conflicting info Re: what PCV valve should be on this model,, the owner's manual call for a Motorcraft EV233,,, every where I check the number's are different,,and I believe not all PCV are the same...thanks |
This is the 2009-2011 F150 forum, you may want to go down the page to the 6.8 V10 forum. They may be able to help you there.
Thread moved to the V10 forum.
WELCOME to FTE! :-X22 |
