Brake line tubing...check this out..
Hey Guys and maybe a gal... I was at my local Parker Store today and the guys showed me a new product they were carrying..They have made brake hoses for awhile which about 1/3 of the price you pay on-line for custom brake hoses..Allot of local hot rodders use these guys..any way they are carrying tubing now..It is a carbon nickel tubing that won't rust and is very easy to work..You can flare it or use compression fittings..very easy to work with. comes in a roll and runs about $3.50 a foot there..you don't have to buy a whole from them just what you need...Here is the websight for the company BrakeQuip Products; Automotive Fittings, Brake Hose and Fittings including Brake Hose Fittings and Others
Never heard of it before. Only stuff I saw recently was something with some sort of plastic coating on a metal tube. "armor-something" in the name.
Sounds interesting though. |
I haven't used it yet....I am going to get some and have it around.....I like the "no rust" and allot cheaper then stainless.
I can't even get stainless here (at least never when I need it LOL)
But it does sound promising. |
At $3.50 a foot too...
Originally Posted by David85
(Post 9850078)
The carbon-nickel lines must be the new stuff the parts guy was telling me about, supposedly even easier than the poly-armor to bend with the same or better anti-corrosion properties... Never tried it tho, not yet at least. |
Originally Posted by LCAM-01XA
(Post 9850281)
You're thinking of the "Poly-Armor", the green-coated lines sold in AutoZone and Advance, likely other chain stores as well. Those actually work great, and they tend to be pretty rust-resistant even when the coating has been damaged.
The carbon-nickel lines must be the new stuff the parts guy was telling me about, supposedly even easier than the poly-armor to bend with the same or better anti-corrosion properties... Never tried it tho, not yet at least. Wow, this is freaky.. I had to replace my front brake like today (runs from passenger wheel to driver wheel). I went with that "poly-armor" stuff. Man, it's sweet! I EASILY bent it by hand and now my truck has brakes lol http://i9.photobucket.com/albums/a87...4/1ba569c4.jpg http://i9.photobucket.com/albums/a87...4/f900f765.jpg |
Did that rub on the fuel line, or one of the rivets for the TTB brackets?
(Post 9850504)
Originally Posted by catfish101
(Post 9849757)
It is a carbon nickel tubing that won't rust....
I didn't see anything on that site that mentioned a price, it seemed more like a wholesaler type website. But last time I needed some brake line, I ordered a couple rolls of the steel stuff and it came out to probably like 60 cents a foot, so $3.50 a foot isn't really the best deal. The stuff I got isn't the fancy plastic coated, but I did paint it before install to hopefully last a bit longer. All I can find for copper-nickel brake line (tube) on ebay comes from the UK and would come in ~$1.50 a foot if the exchange rate and shipping are true. When my current stock of steel line runs out, I might be willing to give it a try if I can find a good price. A better solution in my mind is to stop poisoning our trucks (and the environment!!!) by cutting back or stopping the over salting of the roads. :-rip |
COPPER nickel, not carbon. Big difference there Tell me about the salt...The calcium chloride is allot worse then the salt...Problem is that the public complains so much about the roads and all the taxes they pay etc...It won't stop..... 3.50 really isn't bad for something that will last basically for ever if no holes are rubbed in it..Like silicone heater hose....Last forever if no holes are rubbed in it.. |
Originally Posted by tecgod13
(Post 9850554)
(Post 9850644)
Yes, that was it - "poly-armor". Seemed to work ok, but I am a skeptic at heart so when some one behind the desk says it works great I tend to have my doubts. It did work but it will be at least another 5-10 years before I know if it really is more rust resistant than the regular line material.
You guys think you have salt problems, here they are using the salt brine from gas wells to treat the calcium chloride when they load it on the trucks.
Drops the minimum melt temperature by about 10 degrees. Makes the calcium chloride about 200% more corrosive on your vehicle. Also destroys the roads three times as fast. |
youd think they would have figured that one out by now. damn insane.
