Ford Truck Enthusiasts Forums
-   1973 - 1979 F-100 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum38/)
-   -   Brake line fasteners??? (https://www.ford-trucks.com/forums/1030126-brake-line-fasteners.html)
1eyedjack 01-16-2011 02:40 PM
Hello again
This might be the supidest question of the day but im lost!! I am replacing all my brake lines on my 77 f150 2wd. Every so often there is a fastener that holds the brake line onto the frame. I have broken 2 fasteners so far thinking that i'll probably brake all of them :( . Is there replacments that I can buy? I have tried looking for them online but no suck luck :(
Thanks
OrFordGuy 01-16-2011 02:48 PM
if the local auto parts store can't find one you could use a couple e clips instead..those will fix the hardline to soft line clips... if its the plastis clips in the frame you'll need to go LMC or aftermarket... check some of the hotrod venues they have line clamps for almost anything...
bigdaddys76 01-16-2011 03:55 PM
Go to a local fastener shop or a hydraulic hose shop and buy some "one hole" straps with the rubber inserts and bolt them to your frame.
mikeo0o0o0 01-16-2011 06:25 PM
The original plastic clips are obsolete and as far as I can find, no dealers or obsolete parts suppliers have any and they aren't being reproduced.
They are fairly simple to remove. There is a plastic pin that expands the clip. Take a small pin punch (not a center punch, it has to have a flat nose) and drive the pin back through the clip, then you can remove the clip.
As a back-up you could use small adell clamps and screws to attach the lines to the frame.
1eyedjack 01-16-2011 09:43 PM
Thanks guys. Tomorrow looks like im heading to ACE and pick up a hand full of those udell clamps.
frankalonge 01-16-2011 10:52 PM
I had several broken ones on my '79. I found a company online called inlinetube that sells tons of clips. I used the stainless ELK series on my lines.
