Dually conversion advise wanted
I have a 98 F150 4x4 with a 5.4L Triton motor. I want to convert it to a dually and would like any help or advise from anyone who has experience doing this mod. Any help would be appreciated.
There is going to be quite a bit of suspension swapping you will have to do! Both front and rear.. If you have the D44 up front, you will need to swap out with a D50 or go all out with a D60, then get the dually front hubs, or the D50/D60 dually front hubs. With the rear, you will need the Sterling 3/4 or 1 ton axle and swap out as well. Now thats just the basic "want a dually look". I really wouldnt suggest doing that with a F-150 unless you have a lot of ambition, time and some green.
Thanks for the advise and info. May have to look into other options.
Or, If you are in only for the looks, visit this website!
Welcome - Arrowcraft :: Helping You Handle the Road for over 30 years! good luck, and please let us know if you continue your project?! Bart |
Thanks Bart!! I think this one might get put to bed.
I own a 98 F150 looks like it might be cheaper to just buy a 98 1 ton dully truck.
platform? superduty? 7 bolt?
I'm trying to convert my 7.3 dully to super single need to know tire size I would need I presently use 185 15 r 16
