Rear axle ratio
Hi All,
Just bought a 2000 f250 and the axle space in the door jamb sticker is blank. I crawled under the truck and the tag reads as follows: first line S 409 H second line L 73 10 5 0F08 Truck is a PSD 4x4 w/6spd. |
Rear axle ratio
Since it's a F-250 PSD it only had the option of 3.73 gears, also you have a limited slip differential.
The 3 of what should read 3 L 73 is probably covered by the diff cover bolt. Oh and it's a 10.5" Sterling axle. Hope this helps. |
Rear axle ratio
im not a genious... ok, let me repeat myself... i am not a genious... ok we got that out now...
i would sort of think that the S 409 h might refer to 4.10 gear ratio. i know what you are thinking- 409, and 4.10... 2 different numbers... but when i put 4.10 gears in my old truck, i had to buy the front and rear parts from different manufactures. one box said 4.09 the other said 4.11. my ordered a custom rear end for his camaro, he specifically said 3.90 gear, and it had 3.89 stamped on it..... so.... well maybe im crazy, i dont know |
Rear axle ratio
i would sort of think that the S 409 h might refer to 4.10 gear ratio. i know what you are thinking- 409, and 4.10... 2 different numbers... but when i put 4.10 gears in my old truck, i had to buy the front and rear parts from different manufactures. one box said 4.09 the other said 4.11. my ordered a custom rear end for his camaro, he specifically said 3.90 gear, and it had 3.89 stamped on it..... so.... well maybe im crazy, i dont know what RPMS does your truck average at 70 MPH ?? |
Rear axle ratio
I'll second DCSpecial.
You have a 3.73 limited slip rear axle. Waxy |
Rear axle ratio
Originally posted by BuiltToughF250 im not a genious... ok, let me repeat myself... i am not a genious... ok we got that out now... i would sort of think that the S 409 h might refer to 4.10 gear ratio. i know what you are thinking- 409, and 4.10... 2 different numbers... but when i put 4.10 gears in my old truck, i had to buy the front and rear parts from different manufactures. one box said 4.09 the other said 4.11. my ordered a custom rear end for his camaro, he specifically said 3.90 gear, and it had 3.89 stamped on it..... so.... well maybe im crazy, i dont know what RPMS does your truck average at 70 MPH ?? With the PSD motor, the SRW trucks with the 10.5" Sterling rear only could get 3.73 gears. Only option was if it got a limited slip or not. 4.10s were available on the DRW F-350 PSD. |
Rear axle ratio
ill take your word for it. i dont own a diesel so i have nothing to bring to the table about it.
Rear axle ratio
