7.3 water pump problem
I was driving my 93 f-250 recently when the water pump shaft broke, dropping the fan into the shroud. What could have caused this, is it possible the pump locked up? What is involved in changing the water pump out, as in what else will have to be removed? Thanks in advance.
Did the shaft break or the fan just unscrew from the pump.
Eletrical Problems
Hello to all, I Need help with a 2000 Ford F250 Lariat cc 7.3 diesel. When it rains the horn starts blowing the heater comes on and the inside lights come on all without the key being in the switch, I took the batteries loose to stop all problems . It only do it when it rains, can anyone please tell me where to start?
Originally Posted by Navasota
(Post 9788793)
First wrong section your looking for the powerstroke section. I think two forums up for your year, And second dont hyjack threads start a new one in the proper section. hope you figure out your horn and sorry 302grabber |
I believe the shaft has broke off.
I'm sorry Turbill, didn't mean to step on anyones toes. It's my first time trying to post but i will get it thanks.
no problem nava just looking to help
Originally Posted by 302grabber
(Post 9788942)
As far as replacing it, do a search, there are plenty of threads with good directions. One thing to note, watch out for the bolt lengths, depending on the water pump, some are shorter than others for the ones that penetrate the timing cover. If those are replaced with longer ones, they can contact the timing gears. The new pump will have directions, and I know there is a picture on here if you search for it. |
is there anything wrong wit the rad. or fan? were u leaking coolant before? if so the pump houseing was most likly cracked this happened on my 5.0
Steering Problems
Navasota- Hello to all, I Need help with a 2000 Ford F250 Lariat cc 7.3 diesel. I had all new ball joints put on and now the truck has a lot of play in the steering, it is hard to keep it in the lane when driving are if i hit a bump. what else could this be? my wife is scared to drive with this happening. If you have any imformation it will be greatly appreciated,Thanks
Navasota,
You will get much more help in the correct forum for your truck, this forum is for the PRE POWERSTROKE diesels. i.e. pre 1994.5 ... You want these two forums: 1999 - 2003 7.3L Power Stroke Diesel or Super Duty & Heavy Duty -Enjoy fh : )_~ |
